February 13, 2025, 08:54:50 AM
How many guys to carry a Monster up one flight of stairs?
5
6
Topic: How many guys to carry a Monster up one flight of stairs? (Read 11917 times)
muskrat
Re: How many guys to carry a Monster up one flight of stairs?
Reply #30 on:
October 04, 2010, 02:06:40 PM »
buy some 2x's and ride the beast up. I'm sure your neighbors will appreciate that one.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
Reply #31 on:
October 04, 2010, 02:48:04 PM »
Quote from: Monster Dave on October 04, 2010, 01:37:57 PM
Might not be such a good idea actually, look at the last guy who tried something like this.
Is this thing on?
Reply #32 on:
October 04, 2010, 03:24:45 PM »
what you haven't looked at is safety.
you'll need to drain your fuel tank, remove the battery more than likely, and have an oil absorbtion pad under the bike.
plus the tires and oil will emit fumes as well as the tank unless purged...
is there any safety codes you could be violating? would your lease get canned if caught? etc.
i know i'm being a pisser on the fire... but don't want this cool idea cause you problems
Reply #33 on:
October 04, 2010, 03:28:44 PM »
Quote from: Raux on October 04, 2010, 03:24:45 PM
He'll probably be breaking every fire code in NYC...
but what do tires emit?
S2R 800 '07
Reply #34 on:
October 04, 2010, 04:15:44 PM »
Quote from: humorless dp on October 04, 2010, 03:28:44 PM
After party burn outs can be so much fun, although a bit smelly [moto]
cgv
Reply #35 on:
October 04, 2010, 04:28:41 PM »
+ 1 on the volunteer list.
this could be cool :
http://thatwillbuffout.files.wordpress.com/2010/09/funny-car-photos-rubber-buffs-right-out-right-honey.jpg
(from SU)
speedknot
If a Honda= rice burner, then what is a Ducati?
Reply #36 on:
October 04, 2010, 04:42:21 PM »
This is a funny thread. Go with 3 mules and a camera guy. A 400lb bike going upstairs and around corners could get a bit difficult, but not impossible. Also, a 17" wheel doesn't exactly roll well "up" stairs. If you can rustle up 4 guys then you can carry it up like a pallbearer with some moving straps. 4 guys at 100 lbs each is a breeze. Hope ya got some friends. I saw two plumbers carry a boiler up from the basement using moving straps. It wasn't easy but they did it. A 3 section Peerless has to weight around 500lbs. Possibly?
2001 Duc M750, Harley Forty-Eight, 1976 Honda CB400F-SS, 1975 CB360T
671M900
Reply #37 on:
October 04, 2010, 05:34:06 PM »
Take those 3 guys and have them help you move downstairs. Most logical approach to me
671ducati.wordpress.com
Record of Progress!
For $50 you can touch my
Reply #38 on:
October 04, 2010, 07:10:42 PM »
What could go wrong?
Reply #39 on:
October 04, 2010, 07:28:38 PM »
Quote from: MrIncredible on October 04, 2010, 07:10:42 PM
Yes, indeed.
Like the idea of moving downstairs.
sbrguy
Reply #40 on:
October 04, 2010, 07:56:12 PM »
oh come on, don't be getting all serious and thinking straight here..
of course he would at least drain all the fuel before moving it upstairs only bc it would be lighter to carry, and as far as the oil, afterall people keep bottles of motor oil in their houses at times for emergency purposes what is the difference if 3 quarts "happen" to be contained within a metal container and not the plastic bottles?
this is totally going to be great if this happens.
mattc7
Reply #41 on:
October 04, 2010, 08:12:22 PM »
in gear, strap through wheel (or through a strong frame mounting point, if you are tall enough to use that. One person on each side in the rear.
Ziptie the front brake down. Strap through front wheel, 2 guys in front.
a 5th guy is reccomended, whose sole purpose is to maintain balance, and to let everyone know when it's clear to put down.
it can be done with 2 in back, one in front. I would not do it with less than 3 unless you seriously know what you're doing. It's hard to balance 400lbs of vertical weight, and once it starts tipping...it doesn't come back easy.
671M900
Reply #42 on:
October 04, 2010, 08:40:10 PM »
If they won't let you keep your monster indoors, go buy a house. It IS a monster after all...
Seriously though. how wide is the stairway to begin with? I did push a bike up a flight of stairs with two other guys, but the way we did it was strap the bike down to some 1/2" plywood, and pull and push it up the stairs. That way it can "sled" up the stairs, bust be steady and careful not to let go.
Record of Progress!
Reply #43 on:
October 04, 2010, 08:43:48 PM »
ever been in a room with tires.. they stink
how about the axles. they are hollow. how about a bar though each axle and a man on each end of the bar?
Veloce-Fino
Wiggle-Jiggle
Reply #44 on:
October 04, 2010, 08:45:35 PM »
Quote from: 671M900 on October 04, 2010, 08:40:10 PM
^ DO , possible hilarity is increased by this scenario.
Is this thing on?
5
6
