February 24, 2025, 09:58:27 PM *
Pages: 1 2 [3] 4 5 ... 8   Go Down
Author Topic: REXXER problems - help!  (Read 46374 times)
Desmotwinrider
heute schon geRexXt?
« Reply #30 on: November 09, 2010, 11:23:14 AM »
Hi!
Just a new update because I'll be out of office from tomorrow till end of next week I need some days to clean up my private rooms now...1 week Intermot Cologne, 1 week EICMA Milan and office 10 hours per day waytogo the man who builds the new software for the 64 bit version returns tomorrow in the company, he was out for the Las Vegas car show. This is the reason why I haven't add anything. But i will be available also in my hollifday and if I reveive the new update I will post it!!!
About the CO problem...good news! Now we work together with an expert which has connections to some guys from Continental (they build the ECUs)..he'll get the info where the addresses for the lamda are and how to eliminate it
durable. At the weekend he will get a M1100 and starts working...so if everything goes as it should we'll be able to make the update in no longer than 2 weeks.
Once more sorry for the delay and the long time but to elimintate this problem is not so easy as it maybe sounds..it's very very difficult! That's the reason...please have more patience.
Cheers Chris
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
« Reply #31 on: November 09, 2010, 11:26:45 AM »
Thanks for the update  waytogo
Many of us are waiting for this resolution to make their purchase (myself included)
Is this thing on?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #32 on: November 09, 2010, 01:07:03 PM »
... About the CO problem...good news! Now we work together with an expert which has connections to some guys from Continental (they build the ECUs)..he'll get the info where the addresses for the lamda are and how to eliminate it
Cheers Chris
Sounds promising  waytogo.  When we're kept in the loop (hahaha bad pun) and understand the reasons, then the delay is tolerable.  Thanks for the good communication during your work to resolve this issue.
mattc7
« Reply #33 on: November 09, 2010, 07:56:17 PM »
sweet.  Just ordered today, Chris, thanks for all the time you put into answering my questions, and getting me setup!
I have a spare ecu I plan to Flash this onto.  It was off another 1100 (not mine).  Is there any key mating that needs to occur, or are these pretty much plug and play?
« Last Edit: November 09, 2010, 08:06:58 PM by mattc7 » Logged
Veloce-Fino
Wiggle-Jiggle
« Reply #34 on: November 09, 2010, 08:09:10 PM »
No key mating. There are no "red keys" on siemens bikes, just a "red card."
Should be plug and play.
Is this thing on?
mattc7
« Reply #35 on: November 09, 2010, 08:20:08 PM »
what i meant was more, do i need to input the key code, or just plug it in, flash and go.
key code is not with me.  (bike, me, and code-card) all reside at different addresses.
Veloce-Fino
Wiggle-Jiggle
« Reply #36 on: November 09, 2010, 08:28:12 PM »
Not sure on that one. Raux will know, he has 2 ecu's and has used both.
Is this thing on?
« Reply #37 on: November 09, 2010, 09:05:51 PM »
had no issues.
think the key is coded to the dash?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #38 on: November 09, 2010, 10:20:56 PM »
Just plug in the ECU, flash and you're good to go.
If it was me though, I'd swap the ECU then test before I flashed it, just to make sure this new-to-you ECU functions correctly... and then once that's confirmed I'd flash away  waytogo.
Desmotwinrider
« Reply #39 on: November 10, 2010, 02:05:16 AM »
Good Morning  coffee
Tatata...here you can donwload the newest version of the RexXer software which is compatible also for the Windows 7, 64 bit version:
http://www.rexxer.eu/downloads/rexxer_console_3.80.zip
 waytogo waytogo waytogo
Cheers Chris
Link
« Reply #40 on: November 13, 2010, 06:54:09 AM »
Good Morning  coffee
Cheers Chris
Thanks Chris,  I downloaded it & it works perfectly !
Desmotwinrider
« Reply #41 on: November 23, 2010, 06:28:30 AM »
Hi @ all!
First thx to Link for the feedback, that's the way it should be for the software!!!
As I have written to Steve today, next week we'll have a RexXer workshop and I will meet our Tuner and the new specialist which ist working on the M1100, I will ask them how far it is with the CO function and will keep you update next week!
There is a problem for the service reset, as Steve and Matt written to me! It's not possible to make it for the Siemens ECU at this time and they are right, I have checked and spoken to our engineer and he is working to resolve this problem! For the middle of December a new update will be available that allows you to make the service reset with the RexXer aslo for this ECU!!!
As I have written to Steve, unfortunately such modifications takes a lot of time to program and we have access
to this ECU roughly only half a year and this is very short for the development, thats the reason why not all of the function are available immediately. The Siemens ECU is totally different to the Marellis, for the Marellis we can do everything we want to do because we have a couple of years to work and had enough time to do everything asufindig, I hope this will be the same for the Siemens soon  waytogo
Cheers Chris
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #42 on: November 24, 2010, 04:33:34 AM »
No worries Chris.  Thanks for keeping us up to date.
Desmotwinrider
« Reply #43 on: December 02, 2010, 02:57:06 AM »
Hi @ all!
I'm back in the office, our RexXer course was very good and successfully.
I have also learned some new things by my own  waytogo
Ok I have a short new update for you all about the elimination of the O2 sensors.
We have found a new (3rd) address where the O2 sensor is also located.
We know that there are 4 addresses in the map we have to elimated.
Our technician is now working to find out this last address.
At the beginning of next week we'll get a M1100 for the test run.
I hope that it will not take so long. Most of the work is done now and we are nearing completion.
By the way, maybe some of you guys have one too,
we have also detected the speed limiter for the new Triumph Rocket 3 and we are able to remove it now!
So it will not longer runs 180 km/h...now it runs open end  applause Just for information...please share it with your friends.
In know this is a "Monster" forum  chug
Cheers Chris
DucNaked
« Reply #44 on: December 02, 2010, 08:53:41 AM »
Hi @ all!
Cheers Chris
Thanks Chris....
I'm eagerly awaiting.  popcorn
Pages: 1 2 [3] 4 5 ... 8   Go Up
