Woodcraft Clip ons with stock 696 top triple clamp?
Started by datdude, October 24, 2010, 08:12:23 PM
datdude
Flat black spray can about $7. I actually did them at the same time as the clip-ons since the headlights were already removed.
http://www.autozone.com/autozone/accessories/Dupli-Color-8-oz-universal-flat-black-Perfect-Match-paint/_/N-25gwZ1z10nts?counter=45&filterByKeyWord=paint&fromString=search&itemIdentifier=60036_0_0_
And these (about $15 each) for the exhaust and heat shields after I cored them.  Great results, and after about a year, still looks great! Sounds terrific  [thumbsup]
http://www.autozone.com/autozone/accessories/Thermo-Tec-11-oz-aluminum-high-heat-spray-coating/_/N-261a?counter=0&itemIdentifier=398798_0_0_
DucatiTorrey
after seeing an installed picture of the desmoworld headlight relocate on facebook my big question is can you still relocate the speedo by dropping it down low like Ive seen people do after going the clip on route
  - real place
DucatiTorrey
I am starting to consider 3" rise clip ons, though i would prefer the 2" woodcraft bars when it comes to their relationship to the triple. The 2" IMHO makes the now horribly noticeable speedo stand out like a deuchy tophat. FML. I wish I had the guts to cut that up and drop it down. Have yet to see someone do that though with the stock headlight (even possible?)
hmmmm, yeah, 3" transitions into  stock speedo best.
  - real place
datdude
I think 3" would also solved the clearance issues, because it would be high enough to fit into the air intakes.
In terms of hiding the speedo, I'm thinking about getting these windscreen http://www.ducatiperformance.com/ducati-monster-6967961100-silk-screned-smoked-windscreen-p-1035.html.   It seem to help blend the speedo and the headlights nicely.
Check out our fellow DMFer, L4zy's bike.
http://www.ducatimonsterforum.org/index.php?topic=47164.0
DucatiTorrey
umm, not sure i want another fairing, trying to get the front as low and flat as possible. even considered removing the speedo and hiding the guts i have to keep inside the bike somwhere.
  - real place
I'm pretty certain Ungeheuer lowered the gauges on the stock light.
but yeah. seems the 2" are the wrong fit for the bike. too high to hit below the tank, too low to fit into the air intake
Veloce-Fino
Your options when taking into account turning radius, riding position, and speedo appearance are
A. 3" rise - Fits into cutout, minimal loss of turning radius, lines flow well with stock height gauge pod. (What I have)
B. Zero rise - Bars come in underneath tank on the top trellis tube, minimal loss of turning radius, necessitates lowering of gauges because of how stupid it would look if not done. (What Raux has.)
A is cheaper and less extreme for riding position.
B is cooler, more extreme riding position, and cooler.
It's up to you man.
Is this thing on?
DucatiTorrey
Quote from: Veloce-Fino on March 23, 2011, 01:10:47 PM
It's up to you man.
yep, i like rauxs set up, but would rather not change the light unless i could do the dual round headlights staked, but, i dont thinki could tuck them into the forks deep enough to be satisfied.
stock light it is.
ill take the option behind door number A Bob...
  - real place
Quote from: DucatiTorrey on March 23, 2011, 08:09:15 AM...The 2" IMHO makes the now horribly noticeable speedo stand out like a deuchy tophat. I wish I had the guts to cut that up and drop it down. Have yet to see someone do that though with the stock headlight (even possible?)
You aint been lookin' hard enough then  ;).  It's possible, its not even hard.....
Quote from: Raux on March 23, 2011, 11:33:26 AMI'm pretty certain Ungeheuer lowered the gauges on the stock light.
.....the only hard part is committing to the cut  [evil]
Looks like this when you're done....
..... pulls the speedo in closer to the top triple and lower down to the headlight.  Makes for a neater, meaner, sleeker look IMO.
And here's how I did it for anybody who's interested   >>  http://www.ducatimonsterforum.org/index.php?topic=28586.msg615898#msg615898
DucatiTorrey
fantastic look, i know ive seen it done before.
consider it done
  - real place
datdude
Wow! That is nice  [thumbsup]
DTorrey - make sure to post some pics when you're done.
DucatiTorrey
will do, may be mid may before its complete, but i will post for sure.
  - real place
