February 12, 2025, 05:50:05 AM *
Pages: 1 2 3 [4]   Go Down
Author Topic: Self-abuse- More Porn Outside and Almost Ready to Fire Up  (Read 16093 times)
Oldfisti
My mom says I'm a catch.
« Reply #45 on: April 29, 2011, 09:06:56 AM »
The BBQ idea is good....then I'll have people available to help push me around trying to start it after my knee and hip give out :-)
Right now I am double-checking the nuts and bolts on the bike from the tranny to the tail light
and painting them with Locktite Blue so I know I
A: got to them and
B: to gum up the exposed threads
so when the nuts back themselves out with the vibrations they won't litter the roadways
and bounce up and hit windshields of cars tailgating me
riding behind a British bike is more potentially expensive than tailing an overfilled gravel truck on a bumpy road
RAT - Use the green loctite for this.  Specific use is for already assembled fasteners...
http://www.loctiteproducts.com/p/t_lkr_green/overview/Loctite-Threadlocker-Green-290.htm
thought
Everyone needs a
« Reply #46 on: April 29, 2011, 01:22:50 PM »
looks amazing man, take a vid once you get her started up Cheesy
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
« Reply #47 on: April 29, 2011, 06:46:48 PM »
I want to see the puddle of oil after he shuts it off. Kiss
RAT900
« Reply #48 on: April 29, 2011, 07:44:01 PM »
Nate, as an old Sam Avelino Royal Oilfield fan
you should know that a brit bike does not have to run in order to leak oil...in fact it does not need oil to leak oil
in fact if you park a completely dry one next to a drum of oil...the drum of oil will begin leaking within 3 days
just by sheer proximity   Wink
« Reply #49 on: April 29, 2011, 07:57:25 PM »
Like Sir Winston and his martinis.
The Bacon Junkie
I have a Bacon Wrapped
Save the brass...
« Reply #50 on: April 29, 2011, 09:47:18 PM »
Lookin' good RAT900!  waytogo
bacon
Save the Brass...
« Reply #51 on: April 30, 2011, 06:11:35 AM »
bacon
Agreed
 bacon bacon bacon
RAT900
« Reply #52 on: April 30, 2011, 12:03:42 PM »
OK so the bike is now outside but still has tweaking and fitting issues that need to be sorted out
I had to remove the speedo drive to keep the wheel from binding...the drive lacks sufficient stand-off from the hub cover (it rubs)
so one of the hub or axle spacers that I reused from the basket bike is either incorrect or worn down or something.
The motor is tight...tighter than I prefer but once it fires up that should be self-remedying
So there are a dozen or so things I need to adjust or figure out
The magneto is throwing a yellow spark and not a fat blue one which has me annoyed...got to sort through that
mostly stuff that you don't know and can't know until you start buttoning down the last bits
But we are getting close!!!
« Reply #53 on: April 30, 2011, 02:06:13 PM »
Gorgeous.
 chug
Pages: 1 2 3 [4]   Go Up
