Anyone intall a TrailTech Vapor?
Started by Mike Qube, October 28, 2010, 12:38:40 PM
seanster
Okay cool...
My gauge still working good.  I just want the digital gauge with tach and other stuff (time, and etc.)
If I cut the end of the connector that lead into the gauge, then I need to solder some LEDs at the end of the cut for the lights I needed.
I'm assuming that the kit comes with all the wire for the tach right?
What about your engine temp?
Quote from: The Mad King Pepe' on February 10, 2012, 10:21:26 AM
Not all the pins are used/necessary. You can even go without them if you want...
Is your stock gauge in working condition? If it's a broken POS you can cut the wires between the connector and the gauges and wire those into the LEDs.
For the tach you need a resistor in-line (along the wire). I believe it needs to be at least 600K Ohm.
Edit: pics here http://www.raptorforum.com/forums/showthread.php?t=2616 (first post) show the tach lead (+) that needs to have a resistor wired inline.
The Mad King Pepe'
Do you want the Vapor instead of the stock gauges or as an addition?
Trail tech sells a temp wire for air/oil cooled engines. It has a copper ring at the end of it that you place under your spark plug.
Quote from: seanster on February 10, 2012, 10:43:09 AM
Okay cool...
seanster
Quote from: The Mad King Pepe' on February 10, 2012, 10:48:41 AM
I want the vapor actually...I just want to make sure everything from the stock gauge.
I live in TX so the temp may come handy in April - Sept
