S2R Problems
Started by hackers2r, November 08, 2010, 12:04:04 PM
xcaptainxbloodx
#15
are you sure its electrical?  have you checked for air leaks?
what happend between it running fine and now?
have you checked the wiring loom for any corroded connections?
booger
Quote from: hackers2r on November 08, 2010, 05:20:30 PMJust went on a ride and it is still happening!!!
Sorry bud but I never said that was definitely the problem, only that it was wise to rule it out before you start spending money. It could be a host of different culprits. You should rule out all electrical connections first, because you can do that at home for free. You said the bike was at the dealer and they didn't fix it. Maybe you need a better dealer. Luckily the guy I go to when I'm stumped is a troubleshooter not just somebody who throws parts at problems. You need to find somebody like that, somebody who actually loves these bikes. One indication that a dealer is just such a person is the size of the shop and whether or not they also sell a multitude of other brands. My experience with dealers that also sell Kawasakis is that they don't know shit about the Ducatis.
Good luck with it, I know it's frustrating trying to nail this thing as I've had running problems before as well and they drove me nutz. Part of the experience I suppose. I will go so far as to guarantee you that it's something easily corrected however.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
hackers2r
^I know...just getting really frustrating.  It is getting more predictable though.  Usually takes 15-20 min. of riding to happen.  Only reason I'm continuing to go to the dealer is there is warranty left on the bike.  However, if this isn't resolved shortly, I will be seeking help elsewhere.
Charlief
#18
Quote from: hackers2r on November 08, 2010, 08:03:43 PM
If the warranty is still there I would drop that bike off and tell them you'll stop by every day till it's fixed. If they are a dealer that just throws parts at a bike..... So be it. Your'e not paying for it.
Do you have another dealer in your area?
Did you check the plug wires?  Maybe one is slighty broken.
Bladecutter
I can't find the post where you actually fully describe the actual issue in detail.
Can you provide a bit more as to what is going on for those of us who don't know the full story?
BC.
hackers2r
Sure...so the bike seems to have an issue with intermittent misfires or stalling.  Not really sure which it is.  It has done it for a while but I hadn't really paid that much attention to it until recently when it did it mid-turn and almost put me down.  To describe the actual problem, the bike seems to just not fire once but then keeps running.  Almost like it cuts ignition.
Also, if it were spark plugs, wouldn't this be much more frequent?  Thanks.
It wasn't for me. My bike would suddenly "stop" for a second or a tenth of a second, several times in a row or just once. I didn't really think it could be plugs, but it was my initial thought, so I tried it. It worked. Try it?
duccarlos
Just take it to Chris Boy
psycledelic
Quote from: hackers2r on November 10, 2010, 07:38:19 AM
Might be something completely different, but my 999 was, what I would have called "missing" and eventually starting some howitzer like backfiring.  The shop went through all the electrical, went back to stock ecu, tore the motor down, etc.  Turned out to be the throttle body was bad.  Something about the butterfly valves were messed up and causing the throttle control sensor to tell the ecu that the throttle was momentarely closed.  Like I said, quite possibly a completely different issue, but I thought it would be worth mentioning before you run up a huge troubleshooting bill at the shop.  Excuse any misguided terminology, I am in no way, shape, or form, a mechanic.
06 S2R800 - the wife                         [Dolph]
04 999s - the mistress
hackers2r
Not my tab...bike is under warranty [thumbsup]
rockaduc
What about a leak somewhere along the intake tract?  It could cause a lean condition which would result in the misfiring you are describiing. ???
battlecry
But if it only happens when the engine is warmed up (after ~15min riding), then maybe the lean condition is caused by a faulty temperature sensor (overcorrecting)?
I know coils and ignition components misbehave when hot.  If it is under warranty, it may be the best to leave it to the dealer, because it may take some part substitutions to see what is amiss.  Sorry you are going through this and I hope you have it back soon.  I've had misfires in a turn.  It takes me many rides to get the confidence back.
hackers2r
The bike isn't running lean at all. Was dyno tuned and is running a perfect a/f according to the dealer. This is why I think it is something electrical.
Bladecutter
Okay, now I understand what is going on.
My S2R1000, which I sold to my friend a while back, before buying my 848, started doing the exact same thing last year.
He would be riding along, and then the bike's throttle would become disconnected from reality, and the bike would run like its not getting any fuel or ignition. Eventually the stalling stuttering became so bad, it started leaving him stranded places he didn't appreciate, one of them being the I-25 corridor in Denver, during morning rush hour traffic, in the left breakdown lane, right at 6th Avenue exit.
The cop told him to leave the bike, and let the tow trucks pick up the bike, because it was too dangerous for him to stay with the bike. Right after the tow trucks arrived, because they were blocking the left lane, a 5 car pile up happened when stupid people came flying up, freaked out, and slammed on the brakes, swerving everywhere. They took out a tractor trailer, too, it was that bad.
So, when I got to him and the bike, we brought it back to my place.
First thing I tested was the electrical supply to the fuel pump, because when I would turn on the ignition, I wasn't hearing the pump prime.
Electrical to the pump tested okay, so the computer was working fine.
So I told him to pick up another pump from eBay.
A week or so later, he got the new pump, we installed it, and the bike fired up, first try.
Its been running perfect since.
So, it might be the fuel pump giving you issues.
There have been a couple of posts that tell you how to repair the damaged wire that is typically the cause, if you want to give that a try first.
BC.
hackers2r
Well I've been riding the bike for about a week now after I got it back and this was their resolution.  They kept getting a code for coils.  Swapped out coils but codes still came back.  Checked and cleaned grounds codes came back.  Removed all electronic components, cleaned connections and reinstalled, codes came back.  At this point, they disconnected the headlamp and the codes went away.  Got a call asking if I messed with the headlamp and I said I only changed the bulb to a Hella 55/60 H4 so they ruled that out.  They cleaned the connections of the headlamp, reattached and codes went away!?  In any case, they replaced a few sensors in the process so good for me, but the problem seems to have been solved by the headlight connection.  LMFAO!!!  Unreal.  Thanks for all the help guys.
