February 13, 2025, 04:12:39 AM *
News: Please Help
Pages: 1 2 [3]   Go Down
Author Topic: Hardtail Monster?  (Read 4687 times)
Scotzman
Now that's thinking with your
« Reply #30 on: November 18, 2010, 08:26:58 PM »
Why would they use rust colored wax on the chain?
loves ze desmodromics.
« Reply #31 on: November 21, 2010, 08:16:18 PM »
On hoops:
« Reply #32 on: November 21, 2010, 08:59:55 PM »
Regarding the hoops:
the 851/888 through the 955 Corsa race bikes used the hoop suspension, as well as all 93-2001 Monsters. The hoop connects to a rocker, which pivots on the frame, and is opposed by the top shock mount.
The special race models used an adjustable linkage, the adjustment was through two eccentrics (one on each side) held with pinch bolts, and 'set screws' (to align the eccentrics on each side as the eccentrics used a notched outer diameter) which controlled the location of the top shock mount pivot bolt. This particular rocker (or bridge) was made of two halves with a brace in the middle, quite different looking than the standard rocker, and the hoop bolted between the two halves rather than around the bridge (such as on the monsters).
The billet hoop shown above was one produced by either Febur or Rizoma. The Motowheels m944 had the other manufacturer's hoop:
Pages: 1 2 [3]   Go Up
