February 13, 2025, 03:32:12 AM
Mixing "race fuel" with pump gas-
Topic: Mixing "race fuel" with pump gas- (Read 5357 times)
Re: Mixing "race fuel" with pump gas-
Reply #15 on:
November 20, 2010, 12:32:54 PM »
Quote from: mac900 on November 20, 2010, 11:44:38 AM
I understand the need to run leaner mixtures at higher altitudes but why on earth would octane have anything to do with that? Octane basically deals with how fast the fuel burns and when it starts burning. Lower octane igniting sooner than higher octane and all that.
At higher altitudes, peak cylinder pressure is lower, much like with a lower compression ratio at low altitude.
Radar
Reply #16 on:
November 20, 2010, 03:30:41 PM »
I'm not running a 796, and I don't live at high altitude...
I'm on the West Coast... very low altitude, and I ride an 05 S4R-
I'm not sure how the confusion came about.
Sunoco has various fuels available--leaded and unleaded and oxygenated and non-oxygenated... Octane ratings start at 110-
S4R and stuff-
Reply #17 on:
November 20, 2010, 03:49:31 PM »
All the altitude controversy aside...
race fuels can be very corrosive and require special care for the motor after every time it's run.
I'd avoid them for a street bike.
Reply #18 on:
November 20, 2010, 04:45:53 PM »
The only additive your gas needs.
Reply #19 on:
November 20, 2010, 05:32:28 PM »
im not going to lie, if you gave me a 5 gallon jug of race fuel, id drop 1 gallon for every 2 gallons of regular fuel and use it as is just because its free gas!
justinrhenry
Super
weeeeee!!!
Reply #20 on:
November 20, 2010, 07:03:18 PM »
Quote from: Buckethead on November 20, 2010, 04:45:53 PM
http://www.gixxer.com/forums/showthread.php?t=226570
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
Duc796canada
My first Ducati and road bike!
Reply #21 on:
November 21, 2010, 04:30:06 PM »
Quote from: Radar on November 20, 2010, 03:30:41 PM
LOL...you caught that one too...I think the 796 reference came from me recommending the use of the 89-91 and I ride a "796," so subsquent postings went that way. DOH!!!
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
MadDuck
The anti-
Reply #22 on:
November 21, 2010, 06:30:35 PM »
Quote from: Speeddog on November 20, 2010, 12:32:54 PM
Makes sense now that you put it that way.
NorDog
I don't feel like a
Reply #23 on:
November 22, 2010, 01:51:57 PM »
I use a blend (highly secret ratio) of Mentos and Brawndo in my S4RS. No problems so far, but it is tricky to handle. I have to make sure I don't spill in on any grass, and to keep it away from any Diet Coke.
Randy@StradaFab
Reply #24 on:
November 22, 2010, 03:35:48 PM »
I may be dead wrong but I believe detonation is more about ignition timing than compression. You can have an engine with 8:1 compression ratio and make it ping if the timing is advanced too much.
Reply #25 on:
November 22, 2010, 03:55:18 PM »
Quote from: RMartin on November 22, 2010, 03:35:48 PM
Not entirely.
While it's true that advanced timing can cause a low compression engine to ping...
You can retard the timing on a high compression engine and it may still ping if the octane rating is too low.
Reply #26 on:
November 22, 2010, 09:50:58 PM »
Compression ratio, timing, volumetric efficiency, combustion chamber design, air fuel ratio running temperatures, ambient air temperature and altitude will all affect detonation.
Radar
Reply #27 on:
November 23, 2010, 10:37:20 PM »
Good information in this thread- I appreciate all who responded.
Lots for me to learn about Ducati...
All the best my friends,
Eric M.
S4R and stuff-
