February 12, 2025, 12:05:29 AM
Please Help
DIY LED tail lights
Topic: DIY LED tail lights (Read 12442 times)
J5
I'm here to fix zee fridge
Re: DIY LED tail lights
Reply #15 on:
December 03, 2010, 11:11:40 AM »
Quote from: ajw85 on December 03, 2010, 06:28:01 AM
Is it plug and go?
Resistors built in?
more or less has bullet connectors
i dont know if it has resisters built in as my bike has had an electronic flasher can spliced
into the loom in the past when the blinker circuit in the clocks went kaput
either way resisters can be had on ebay for not much dollars
Duc796canada
My first Ducati and road bike!
Reply #16 on:
December 03, 2010, 09:18:55 PM »
My 796 comes with LED tail lights, bought a plug in for the flashing brakes from viz-tec, aka ohmic. I personally don't like the intergrated brake and signals, for the reason that someone might not be paying attention or not know what the flashing show is all about and run into the back my bike. I want a clear stop light and amber turn signals, separate, no question what is what.
I took electronics in college and can easily build a circuit with LEDs, just much easier to buy it. I don't like re-inventing the wheel.
Love the vizi-tec sup-brake flashing light.
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
J5
Reply #17 on:
December 03, 2010, 09:56:18 PM »
eyduc
Reply #18 on:
December 05, 2010, 08:22:02 AM »
Now that I think about it more, I don't like the integrated lights either. Left and right is too close together in the same light assembly. I'll likely just make a tail light/brake light. I'm reusing the stock lens and slightly Dremeling the back plate to fit a pcb. I'll keep my Flickr site updated as I progress, if anyone is interested.
I do electronics mostly everyday. I don't think "I have to be old and retired and with nothing better to do" just to make something I want. It's a piece of cake. I'm sure mostly everyone here has made something by themselves that is on their bike. If I can't make it, I'll buy it too. But if I can, I will.
eyduc
Reply #19 on:
December 05, 2010, 08:23:28 AM »
J5, where did you buy the frame plugs?
J5
Reply #20 on:
December 05, 2010, 10:37:53 AM »
Quote from: eyduc on December 05, 2010, 08:23:28 AM
they were on it when i bought it
prob a hardware store or something i imagine
roy-nexus-6
Reply #21 on:
December 05, 2010, 07:53:24 PM »
Quote from: eyduc on December 05, 2010, 08:22:02 AM
LED globes/indicators fitted inside the frame (instead) of plugs work well. I'm currently making a matching tail light.
Duc796canada
Reply #22 on:
December 05, 2010, 09:55:10 PM »
Quote from: roy-nexus-6 on December 05, 2010, 07:53:24 PM
I have seen that girl in your sig block on youtube dancing, ...she can move!!
PC V, NEXTUP QS.
roy-nexus-6
Reply #23 on:
December 06, 2010, 01:56:17 PM »
Quote from: Duc796canada on December 05, 2010, 09:55:10 PM
That she can! The video is an oldie, but a goodie!
DarkStaR
Reply #24 on:
December 06, 2010, 03:25:43 PM »
Someone gave me one of these, and it's better than stock. It's brighter than some of the cheapo LED boards, but way more convienient.
Last Edit: December 06, 2010, 03:32:04 PM by DarkStaR
eyduc
Reply #25 on:
December 06, 2010, 03:43:15 PM »
That was my first thought. LED bulbs that just replace the 1157 bulb.
This one is a 19 LED version. The thing I didnt like was the light was concentrated instead of being spread out like an LED board.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2F1157-R19W6_motorcycle_bulb.htm
eyduc
Reply #26 on:
January 13, 2011, 06:06:55 AM »
Ok, all done. Here is the bare board loose on the oem reflector:
Here is a top view:
It was fairly simple to build. I had to cut the oem reflector plate so the pcb will lie flat. I used cut off hose for vibration isolation. The pcb is from Mouser (4x5, double sided plated thru), about $12. The Piranha LEDs are from SuperBrightLEDs (.25 ea). I liked these better than the normal T1 3/4 5mm LEDs because they were brighter and had 4 pins with which to solder to (more durable for vibration). There are 9 strings of 4 LEDs, 9 running lamp resistors (550 ohm) and 9 brake light resistors (220 ohm). I set running current to be about 10ma each circuit (x9) and the brake light current to 30ma (x9). The max current is 40ma. I wanted it to be a little understressed. I am currently wiring up a flasher relay (EP35) with a 5 ohm load resistor for the brake light. I wanted more visibility during braking. In the back, the hole was just the right size to push in the OEM license plate light.
Here is a shot of the LED turn signals from Monster Parts:
Here is a shot from the rear with it all bolted up:
Jarvicious
The guy in my avatar wants your
Balls
Reply #27 on:
January 13, 2011, 06:40:11 AM »
Action pics. Action pics!
We're liberated by the hearts that imprison us. We're taken hostage by the ones that we break.
eyduc
Reply #28 on:
January 13, 2011, 06:46:33 AM »
Shot of the running light:
It's hard to take the brake lights but I'll try again later tonight. I also have a vid but I'll upload and post it tonight. When the brake lights turn on, the camera exposes it darker (like shooting in snow) and all you see are bright leds in a dark room. It doesn't help that the background wall is (Ducati) red!!
sbrguy
Reply #29 on:
January 13, 2011, 07:46:18 AM »
that looks very good, you might have a nice product on your hands here to sell people if it works well and is really bright.
