The coffee thread
Started by Bun-bun, December 19, 2010, 09:08:13 PM
Quote from: kopfjäger on March 07, 2017, 02:44:11 PM
You're doing far more damage to it in the fridge. Try this, it'll seal up the gaps.
Really? I'm just getting into this, how does being refrigerated adversely affect it?
Kopfjäger
Quote from: NAKID on March 07, 2017, 03:22:50 PM
You'd have to read up on it. I do know that the fridge make the beast with two backss it up.
http://www.ducatimonsterforum.org/index.php?topic=45144.msg1357618#msg1357618
Quote from: kopfjäger on March 07, 2017, 03:29:07 PM
Well shit. Just did a little more research and there doesn't seem to be any consensus. Everything from brew at room temp with room temp water to in the fridge with ice water, 8-12 hours versus 18-24 hours and everything in between. Then there's the folk who brew it for well over 24 hours then dilute it 50/50 with either hot or cold water (or milk, no thanks).
Kopfjäger
I go 12hrs ish, room temperature. Avoid the fridge during brewing. Them little beans get chilly in that cold water and don't deliver the full punch.
Quote from: kopfjäger on March 07, 2017, 04:09:30 PM
What's your coffee to water ratio?
Kopfjäger
Quote from: NAKID on March 07, 2017, 04:17:33 PM
I just eyeball it. Usually 4-5 scoops ground Fresh' for the press. Fill it with water.
Quote from: kopfjäger on March 07, 2017, 04:37:08 PM
OK, that's about what I've been doing...
Kopfjäger
Quote from: NAKID on March 07, 2017, 04:44:57 PM
If you can hold your hand semi still, it ain't strong enough.  ;)
I'd soooooo wear that to work if it were kosher.
Kopfjäger
Charlie98
I bought my wife a KitchenAid cold-brew maker for her birthday, it seems to work pretty well.  It has a microperf 'drum' you set in the middle full of coffee and you pour water through it and let it set for 24.  I don't know if she puts it in the fridgeitater to brew or not... I'll have to axe.  My only complaint, besides the $100 price, is it doesn't make just a whole lot... I think it yields around 60oz... and it uses a good deal of beans.
Dennis
2013 M796 ABS
Kopfjäger
Quote from: kopfjäger on March 07, 2017, 04:59:08 PM
:D
