Dainese Back Protectors
Started by DRKWNG, January 02, 2011, 03:28:23 PM
I've got a Wave Gillet you're welcome to take for a test drive.
Quote from: Sad Panda on January 05, 2011, 08:17:51 AM
Thanks.  I might just take you up on that.  Well, after it warms up that is.   :D
Just curious, but are you looking at Big D stuff to the exclusion of other brands?
Only because there are some pretty good deals on their kit right now.  Ultimately I would probably go with either Dainese or Knox.
Both good brands, no doubt. Have you thought about T-Pro/Forcefield? Spidey has done quite a bit of... ahem... "field research"... and seems quite pleased with them. I'll probably be picking up one of their "Sub-4" protectors later this spring as the bike gets closer to rideable.
Ben, I've got a Forcefield level 1 separate as well you can try. The Dianse one is the vest sort with chest plates, the Forcefield is just the back w/ shoulder and waist belt
