Next Set of Mods - Suggestions for 05 S2R800
Started by TitanMonsterS4R, January 08, 2011, 06:36:02 PM
xcaptainxbloodx
#75
have you thought about powdercoating the rest of the speedymoto covers black? it would make the yellow pop better and flow with the bike more (IMO) you could do the headlight ears/loop at the same time for very little extra im sure.
I would say do the footpegs too but for that to really work you would need to do the swingarm/case covers and that is a expensive and timely process in itself.
plus if youre going that deep its a good time to do the lightened flywheel/slipper clutch if you ever want to. then of course you need a black clutch slave to match the case covers. and if your getting into that then you should find a better clutch master and some custom lines(black right?). but then you need to match them and in that case you should get better calipers and custom lines there too. and if your going that far then you simply must..... ;D
TitanMonsterS4R
Quote from: xcaptainxbloodx on January 27, 2011, 07:56:11 PM
custom lines(black right?)..... ;D
En route from another member.  Not sure whether his line will work with my rear brake line but we shall see....
Never thought about doing the rest of the belt cover black but not a bad suggestion.  Winter is still here for another 30+ days so I have plenty of time to burn cash.... [coffee]
badgalbetty
s2r comes with a type of slipper clutch from the factory. They are amazing.... [thumbsup]
Quote from: badgalbetty on January 29, 2011, 08:57:37 AM
although not a true slipper, they do work well. the same is in the 696.
I found out from the EVR folks that there is no true slipper in their lineup for the smallcase motors.
BUT he's thought about it.
TitanMonsterS4R
BGB - what type of glue/fix did you use to get the S2R badge to fix to the tank?  Just got two more to put on the new tank...
Privateer
I didn't read all 6 pages so I don't know if someone else mentioned this.  sorry if I'm repeating.
reroute the starter wire around the left side of the bike to further clean up the belt area.
and tuck that overflow hose somewhere it can't be seen.
badgalbetty
Those are the side panel badges . I just used the backing that comes with them. They are self adhesive and went on with no problems......just peel and stick! I never saw anyone else with done to their bike and it looks like they were made to go there......  [thumbsup]
Make sure that you get an idea where you want them before you apply.....do some measuring which I didn't, I just eyeballed it and hoped they were straight......
Erica
TitanMonsterS4R
Quote from: Privateer on January 29, 2011, 11:40:47 AM
working on cleaning up the belt side.  Might rattle can spray the rest of the belt cover stuff although I should just have it PC'd like I've already started with...
Quote from: badgalbetty on January 29, 2011, 12:33:03 PM
Erica
[thumbsup]
The Mad King Pepe'
From reading bikeboy.org it seems that a 2 in 1 exhaust might end up robbing some power from the engine. Not a huge deal, but I would take it into consideration when dropping $$ on an exhust.
TitanMonsterS4R
Update.....
Added the yellow/black stripped belly pan, SSR gas cap, clear front turn signals and integrated rear brake light/signals and CRG levers.  Have a healthy balance of yellow and black with the bike.  Purchased and installed a Marving midpipe and 2 in 1 exhaust.  Like the midpipe, hate the exhaust.  Not sure what to do regarding the exhaust.  Painted the stock udder flat black and threw it back on the bike until I figure out my next move....
Meanwhile, I picked up brembo radial master cyclinders from and 848/1098 to upgrade the brake/clutch.  Makes a world of difference now [moto]!  Brake feel is much more responsive.
Also got my hands on gold annodized rear sprocket flange, kickstand (stock one needed to be replaced) and a rear, front axle nut.
I ordered a 4Racing rearset OVER a month ago [bang] and it still hasn't arrived.  Might have to go with plan B (Rizoma) if my shipment off the boat never appears.
Next things to find:
320mm rotors
10 spoke wheels
Exhaust
badgalbetty
the 320 mm rotors on the front were brand new a couple years ago. They may have a couple thousand miles on them.
Erica.
TitanMonsterS4R
Quote from: badgalbetty on March 26, 2011, 10:24:26 PM
Erica.
i love the rotors  ;D.  Just thinking when its time to change would like to find a pair with a rare pattern.  She runs like a champ!
rockaduc
TitanMonsterS4R
Some new goodies just arrived. Rearsets
Lookie lookie.....
