February 12, 2025, 04:05:35 AM *
Pages: 1 ... 160 161 [162] 163 164 ... 265   Go Down
Author Topic: The DFWM say anything thread  (Read 423979 times)
bryant8
2008 848 White
« Reply #2415 on: March 24, 2009, 05:37:54 PM »
Looks/sounds good!
I bought a new Dainese back protector for track days.  I thought my 1pc suit was snug before but now... yeesh
26.2 done 12/5/2010
70.3 by 10/12/2011
140.6 by 12/31/2012
Ronr
« Reply #2416 on: March 24, 2009, 05:56:55 PM »
That is just the right combination of clutch clatter and exhaust loudness
Samsonite
« Reply #2417 on: March 24, 2009, 05:59:38 PM »
+1
Suzuki DS 80   Suzuki SP 125   Suzuki GSXR 1000   Ducati M600   Ducati SC 1000   Ducati S4R 1000   Ducati PS1000LE   Ducati 1098S   Yamaha YZFR 1000   Yamaha YZFR 600   Ducati Sport 900   Yamaha YSR 50   Triumph Daytona 600   2006 Suzuki GSX-R 600
fastwin
« Reply #2418 on: March 24, 2009, 07:56:03 PM »
Me too. Baffles out. waytogo
fastwin
« Reply #2419 on: March 26, 2009, 11:45:13 AM »
Nice story and write up on the last of the S4RS bikes.
http://www.superbikeplanet.com/2009/Mar/s4rs.htm
caffeinejunkee
« Reply #2420 on: March 30, 2009, 07:18:18 AM »
I am also looking to set up the track challenge 999 vs Busa vs R1 ..... winner take all.
What do you think, maybe each of us put up like $500 with the best bike taking the prize.
You're going against an R1 and a Busa?
 popcorn
Samsonite
« Reply #2421 on: March 30, 2009, 07:31:06 AM »
 popcorn
ooh! We can do a mini cannonball run.... Muenster run...... Loser buys lunch and has to wash winner's bike
alexisonfire
« Reply #2422 on: March 30, 2009, 11:27:44 AM »
North Eastie meet anytime soon?  We've got a big enough group up in the Plano / Frisco area to do a miniature meet weekly or every other week.  I wanna see Jim's new ride as well.
Should this be a new topic?
You can live to 100 if you give up all the things that make you want to live to 100.
07 S2R 1000
Samsonite
« Reply #2423 on: March 30, 2009, 11:30:20 AM »
Post a new topic, one thing is for sure.....if you plan it, they will come bacon
alexisonfire
« Reply #2424 on: March 30, 2009, 01:35:10 PM »
Cool, I'll post something up tonight.
I just finished my first clutch fluid flush.  I was a little nervous but i nailed it pretty easily in about 20 minutes.
I'm sure I have a leaking slave cylinder for the following reasons:
First, my clutch fluid reservoir level has been steadily depreciating during my 9 months of ownership.  Dax points at it quite often and I tell him, "Ya ill do something about it sooner or later."
Second, while flushing the system I noticed three droplets that had fallen underneath the bike.  The trail led to the bottom of the slave cylinder housing.  I checked the bolts and everything was tight.  Looks like the seal has gone.
Any input?  I'll probably use this as an excuse to go with an aftermarket slave.  Recommendations?
07 S2R 1000
Cher
Mostly Harmless
« Reply #2425 on: March 30, 2009, 01:36:50 PM »
+1    Grin
Ronr
« Reply #2426 on: March 30, 2009, 03:03:04 PM »
You can easily remove the three screws that hold on the slave cylinder, and check the inside area for a leak.  You can also check the o-ring seal that goes around the push rod that pushes the clutch pressure plate.  I think that one is more for preventing motor oil from getting in the slave, but mainly look for clutch fluid in that area where there shouldn't be any.  Not sure if the slave piston has replaceable seals, although it should. I hear they are notorious for leaking, and is one of the reasons many people go to an aftermarket slave.
fastwin
« Reply #2427 on: March 30, 2009, 03:57:38 PM »
I'm one of the "many people" he is referring to. laughingdp All my Ducs have Evoluzione clutch slaves. Many other good aftermarket ones out there. I am sure they all work better than the stocker. Leaks or not they make clutch lever pull much better, probably 20-30% easier for sure. A lifesaver in a stop and go traffic jam. Reduces the arm pump and hand cramp to Jap bike levels! laughingdp waytogo [moto]
alexisonfire
« Reply #2428 on: March 30, 2009, 04:32:03 PM »
I shouldn't expect any fluid to come flowing out by removing the slave cylinder should I? (unscrewing the 3 mounting bolts)
Well, other than leaking clutch fluid.  Undecided
07 S2R 1000
Ronr
« Reply #2429 on: March 30, 2009, 05:11:24 PM »
Not at all.  Should be quite dry.  The red o-ring keeps the oil from getting from the engine into the slave (and vise versa in your case  Smiley )
Pages: 1 ... 160 161 [162] 163 164 ... 265   Go Up
