ML's machine shop thread
Started by Monsterlover, January 31, 2011, 03:39:33 PM
freeclimbmtb
#977
Intake manifold for something with a 2bbl updraft carburator.  Aircraft engine?
EDIT:
Wait.  Its steel.
Dual discharge positive displacement pump of some sort..
And those are some pretty blue chips you got there...quick feed?
2011 Monster 796 ABS
Quote from: freeclimbmtb on January 08, 2013, 11:39:57 AM
EDIT:
Wait.  Its steel.
Not for a pump.  Internal combustion engine.
Blue chips, lol.  Worn out inserts ;D  They've been in that cutter for the past year with intermittent use.
freeclimbmtb
Quote from: Monsterlover on January 08, 2013, 01:33:22 PM
Intake for a Toyota 22R.
I'll give you a hint.
It's an intake and an exhaust manifold
zooom
Quote from: Monsterlover on January 09, 2013, 09:22:18 AM
Mazda RX project?
2010 KTM 990 SM-T
it is for an engine whos intake and exhaust are on the same side . . . VW had those. . . Opel had those . . . some US 4 cyl engines were like that . . .
and then the missing, for us, part will be welded together with this one to form one part that will serve as intake and exhaust manifolds . . .
[popcorn]
Quote from: Darkmonster620 on January 09, 2013, 10:05:58 AM
[popcorn]
But also
