Keihin FCRs Vs Mikuni CV carbs
Started by koko64, February 12, 2011, 03:15:25 PM
With no enrichener, you learn to use the accelerator pump to squirt fuel into the manifolds and hold the throttle at just off idle/fast idle. A richer Idle mixture setting in winter helps. So more involved to start, but runs better in the cold with no freezing and great performance.
PhilB
Quote from: koko64 on December 10, 2012, 02:26:06 AM
Thanks.  I might well look into that next time I need carbs.
PhilB
1993 Ducati M900 Monster "Patina" (203,000 miles, so far) -- 1995 Ducati M900 (wife's bike) -- 1972 Honda CB450 (daughter's bike) -- 1979 Vespa P200 (daughter's scoot) -- 1967 Alfa Romeo GT Jr. (1300cc) -- 1964 Vespa GS160 (160cc 2-stroke) -- 1962 Maicoletta scooter (275cc 2-stroke) -- 1960 Heinkel Tourist 103A1 scooter "Elroy" (175cc 4-stroke)
showerfan
phil -- how did you `beef up the starter system?'
Give me a shout if you know any good motorcycle detailers in the Westchester area.
PhilB
Quote from: showerfan on December 10, 2012, 07:44:44 PMphil -- how did you `beef up the starter system?'
Mainly by upgrading the wires from the battery to the relay, and from the relay to the starter, from 6ga to 4ga, and adding a dedicated ground line back from the starter to the battery instead of relying on grounding through the frame/engine.  I also was able to get a stronger battery that was the same physical size as the original.
PhilB
Autostrada Pilot
+1 on a wiring upgrade for the starter.  Made a HUGE difference in how fast the 900 carbies start.  I ordered the Powerlet kit for like $30.
2003 Monster 620 Dark - Sold
1999 Monster 900 City - Sold
dlearl476
#35
Quote from: PhilB on December 09, 2012, 07:56:30 PM
I'm interested in the comments about cold weather.  My original carbs wore out a couple years ago, so I had the choice.  I was worried about the lack of an enrichener, and stories that bikes with the FCRs can be harder to start, especially in cold weather, so I got a used set of the OEM carbs.  They seem to do alright in the cold, once I beefed up the starter system.
Are the FCRs actually good in cold weather?
PhilB
Phil, if one of those stories was mine, I apologize. My cold wether starting issues were completely self-induced. I installed the Powerlet kit and had my carbs adjusted and it helped a bit but not much. Couldn't get the bike started to go on a New Year's Day ride.
I was working on that and changing the belts the other day and the friend who was helping me/showing me how to do it noticed that the battery I had was way underpowered.
See, when my OEM batt died a couple of years ago, I didn't want to replace it with a wet cell and the Westco dealer sold me what he said was listed for our bikes. Well, it was a 9Mah/120CCA batt when spec calls for a 10Mah/150 CCA BATT. (IIRC)
So installed a TrueGel gel hybrid battery yesterday (16Mah/190CCA) and it fired right up the second I hit the starter button on a 35 degree day. Don't know whether to jump for joy or kick myself in the ass.
Otherwise, ditto to all the praised heaped on the FCRs. I like them so much I want to get a pair for my F650.
PhilB
Quote from: dlearl476 on January 11, 2013, 09:09:16 AM
Alright.  Well, the carbs I have on there now only have about 50K on them, so maybe 10 years or so down the road when they wear out, I'll give the FCRs another look.
PhilB
