February 12, 2025, 01:58:28 PM *
Pages: [1] 2   Go Down
Author Topic: Tire wear & Slab Riding. - Ways to minimize tire squaring,  (Read 5732 times)
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
« on: February 16, 2011, 08:52:27 PM »
Last season commuting to and from college just once each way resulted in some squaring of my rear tire.
~140 miles each way in blistering heat, all highway.
After making this trip my rear tire on the 696 was noticeably squared.
I'm wondering if lowering the PSI a bit, maybe to the minimum recommended psi or 1-2 lower will reduce the amount of squaring as a result of slab riding.
My only other option is light up the rear tire and wag the bike back and forth and hopefully round it out a bit.
^ - this option sounds more fun.
Any other recommendations?
Is this thing on?
Heath
« Reply #1 on: February 16, 2011, 09:13:53 PM »
Next time you get tires buy something that is more for touring. Like a Pilot Road 2, it has a harder compound on the center.  I do not know what tires come stock on the newer monsters.
In the meantime maybe change your route up and find more curves.
« Last Edit: February 16, 2011, 09:17:02 PM by Heath » Logged
2007 Ducati Monster S4RT
« Reply #2 on: February 16, 2011, 09:31:59 PM »
I'm in the same situation 88 km total on autobahn with about 10km of it curves near my house.
I went with the Pilot Road 2
so far not bad, and the profile is more aggressive than the stock so the corners fall in faster.
Veloce-Fino
Wiggle-Jiggle
« Reply #3 on: February 16, 2011, 09:55:36 PM »
The problem is, I will only be making this trip 3-4 times this season.
All my other riding very "spirited" and on some nice twisties.
I don't want to sacrifice grip and control when riding by getting a touring tire when I'm only on the highway a limited number of times.
I'll look into this. Getting new tires put on for the season. If it wasn't for those couple highway rides I'd get Pilot Pure's, but they would almost certainly square off, even on just one 130m trip.
Is this thing on?
ab
ab
ab
« Reply #4 on: February 16, 2011, 10:05:42 PM »
I hit the twisty on pilot 2.  Even with that, I had to do 3 tire changes last season alone due to wear.
The non dual compound got to be too expensive to replace.  I am sticking with dual compound.
Veloce-Fino
Wiggle-Jiggle
« Reply #5 on: February 16, 2011, 10:28:19 PM »
http://www.michelinpowerpure.com/en/michelin-2ct-technology.html#2ct-
Interesting diagram of the 2CT and Pure. Basically the same dual compound tire however the pure has more of the softer compound sooner. The 2CT has majority of the stiffer compound.
There is a whole thread on the power pure, going to look into that for my next set. Hopefully the stiffer center compound minimizes the squaring. Based on some reading I just did dropping the psi slightly can help reduce squaring as well.
Is this thing on?
« Reply #6 on: February 16, 2011, 11:17:06 PM »
Im not to judge but most people dont really go over the edge on the street whe nit comes to a sport tire. I have the pilot road 2ct at i think 13,000 miles now. its squared, but still lasting. I took it to 3 trackdays and it was very sticky, you can feel it slip it a bit if it got really hot and you were super aggresive, but even then,  i dont think you can reach that on the street.
zooom
« Reply #7 on: February 17, 2011, 04:16:54 AM »
MY .02...just a buy a spare rear wheel, and put a hard slab ridin' kind of tire on it and do a wheel swap when you know you are going to do your commute and the rest of the time, you'll have your whatever-floats-your-boat kind of tire on regularly...and this way, you'll also remember to check your chain tension/alignment and adjust as necessary maybe a lil more frequently...
2010 KTM 990 SM-T
The best kind of whore is a
« Reply #8 on: February 17, 2011, 06:25:31 AM »
What size engine do you have feeding that 13,000 mile rear tire?!?
Im running a 180 PR2 on my 950supermoto and it's almost toasted at 4500 miles Shocked
« Reply #9 on: February 17, 2011, 09:51:30 AM »
S2R1000 Pilot Road 2ct. Its pretty squared off, but it still has tread so  whatever. Tongue, i wont change it until the cords start showing.
A lot of things factor into life. 70% of it is highway miles, 30% is low speed commuter miles, also the type of pavement you ride on. Concrete i would assume is much rougher than asphalt.
also a supermoto is ridden different.  waytogo
RBX QB
« Reply #10 on: February 17, 2011, 10:24:27 AM »
I got 9k on my stock Pilot Power... Roughly 10k so far on my current Pilot Power 2, with some squaring off. Not nearly as square as the original Power was. It's now needing replacement, as I am feeling the wear edge when the tire rolls. Going with the Pilot Road 2 for my next, figure I'll get 50k out of it.  Grin
Most of my ride is short commute, with occasional trips passing 200 miles, both freeway and mountain. I definitely don't ride agressive (except 0-60  Evil), because my tires seem to last so damn long.
« Reply #11 on: February 17, 2011, 10:36:46 AM »
Huh. I remember when i bought my pr2. I rode to dimby and back, 1200 miles and the rear had already started to square up. Most of that was slab.
loves ze desmodromics.
« Reply #12 on: February 17, 2011, 10:52:33 AM »
I would think raising it slightly to minimize the amount of tire that is subjected to squaring would be more ideal, but not sure either way
cokey
hey take a look @ my
« Reply #13 on: February 18, 2011, 09:50:08 AM »
could that be from riding on the tire that long and heat being a factor.. rather then the tire hardly warming up on short commutes?
I WIN
Quote from: my wife
Ok babe I surrender to u.  U may work me out till I drop
About the goat...
« Reply #14 on: February 18, 2011, 09:53:01 AM »
Probably not much heat.  10 hours of hard rain put a stop to that Wink
Pages: [1] 2   Go Up
