Back Protector Recommendations?
Started by The Architect, June 12, 2008, 02:11:58 PM
Spider
that BMW stuff does look good....was thinking about replacing my shoulder pads with it.
anything Cert 2 is impressive!
Bizzarrini
Hi Guys,
here in the Netherlands a biker mag performed a test of different back protectors, and the results were quite shocking. They tested 13 protectors, and of these, 8 didn't pass the test! A short summary of the results (too bad the test is in Dutch, otherwise I'd include the pdf):
Acerbis Atlantis 59:                         failed
Alpinestars Tech Backprotector:        failed
Axo Backprotector:                          failed
BWM Protector 2:                            failed
Büse Protectorvest Belluno:               test winner!!
Dainese Wave:                                passed
Erbo P8:                                          failed
Götz P9:                                          failed
Hein Gericke ProSports Safety Shirt:  passed
Held Backprotector:                          failed
Louis Super Shield:                          failed
Polo Prolife:                                    passed
Rukka Airpower:                              passed
Testing was performed according to CE 1621-2 guidelines, measuring remaining impact in five zones within the protected area, after a collision. After reading this, I immediately bought the Büse vest, and I'm quite satisfied so far!
http://www2.buese.com/websitev3/html/endkunde/artdetindexjacken.php?wgruppe=18B&kurzbezeichnung=BÜSE Protektorenweste&farbe=schwarz
Cheers!
"As a final touch, God created the Dutch"
IdZer0
Any detailed info on these tests. I don't like to go on pass/fail results alone.
replaced by 2011 848 EVO
The Architect
Thanks for all the help.   [beer]
Since budget was in issue, I ordered on of these  http://www.highvelocitygear.com/productpages/velo-shield.html
It got a lot of good reviews.  As soon as I get it I'll post my initial comments.
Bizzarrini
Quote from: IdZer0 on June 17, 2008, 05:44:16 AM
I'll try and translate a bit more as soon as I have the time, and I'll include some force measurement data.
Would certainly help if you could read Dutch though  ;D
RodeoClown
Quote from: red duke on June 17, 2008, 06:12:35 AM
red duke
How do you like this back protector?
2000 M750 Dark(Black Betty); 88 FZR400
IdZer0
Grio
I ride with the T pro...very comfortable...
It allows ariflow and is very thin and flexible; it is also designed to withstand multiple impacts.  Some protectors aren't (the Dianesse Wave, for example).
Little Biscuits!
RodeoClown
Quote from: Grio on July 28, 2008, 11:19:33 AM
Have you run into any problems with track day schools wanting a hard back protector?
Grio
None at all...in fact, I don't know if I have ever seen "requirements" listed for back protectors at all.
Most of the local racers that use top of the line gear and sport custom suits use a soft type back protector.  Yes there is always that risk that hard shelled armor could resist an impaling type injury,   But those are few and far between, and hardshelled armor does not perform as well in some other areas.
Little Biscuits!
RodeoClown
Thanks for the info!
Dont the hard shells also play a roll in preventing over-extension of the back? Not sure how important this is either in preventing major injury over protecting against impact??
q monster
just got the dainese Wave 2 V neck - comfortable and better neck protection than anything else tried.
q monster
2008 S2R1000 changed - spark headers and tail cut done, rizoma grips indicator lights and clutch cover titax levers, DP ECU, open filter, ...... maybe stop then............. nah think i'll add rizoma rearsets and their conical handlebar is f..hot... and then i need to get rid of those mirrors....
COWBOY
Here's a link to the thread with the latest BP test results in Ride! magazine
http://ducatimonsterforum.org/index.php?topic=7130.0
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
The Architect
Quote from: RodeoClown on July 28, 2008, 08:11:31 AM
red duke
So far it's been good.  I haven't used it for a trackday yet.  Very comfortable.  You forget it's on after a few minutes.  I do like the hard shell.
The only thing I haven't determined is if I should leave in the soft back protector that came with my suit (non CE approved) when I wear this velo back protector.
