October 06, 2024, 11:15:00 PM
'04 MS4R not idling correctly
Topic: '04 MS4R not idling correctly (Read 6282 times)
normalcyispasse
Re: '04 MS4R not idling correctly
Reply #15 on:
May 31, 2011, 02:41:59 PM »
Well, still no luck. I had the fuel injectors cleaned and flow tested. Both passed (rats). Plugged 'em back in, and the bike still idles poorly. For the life of me I just cannot see any vac leaks, though that's what it sounds like I have.
At least compression is good (179/171 f/r).
It might just be time to haul it into a shop. I've been trying for almost five months to fix this problem and it has just eluded me time after time.
normalcyispasse
Reply #16 on:
June 01, 2011, 04:11:58 PM »
Propane and propane accessories. . .
Monster S4R idling poorly: Propane and propane accessories
Looks like there's a vac leak at the front butterfly vane.
. . . how on earth do I fix this?
liquidsmile
Reply #17 on:
June 01, 2011, 06:58:57 PM »
First put the ECU trim back to 10 or less
second Zero the TPS correctly
third Sync the throttle bodys at 3K RPM
fourth, set the CO at idle by using the bleed screws- set level to 2.0-2.75 or maybe a little less for your inspection. should be 4-6 for best performance,
If the HC level is high at this point do a leakdown test
My guess off the bat is that a valve is leaking, either through out of spec or through a valve guide.
Certified Ducati Master Technician
Owner of
Ducati Greensboro - NC's only Exclusive Ducati Dealer!
2005 Monster S4R
2009 1098R Bayliss LE
-Too many options to list-
normalcyispasse
Reply #18 on:
June 01, 2011, 07:17:40 PM »
It failed emissions at +8 and passed at +15 but hasn't idled correctly.
TPS has been zeroed very recently, and throttle bodies have been synchronized well. Bleed screws have been similarly set.
Valves have been examined, and all are within spec.
I could do a leakdown test, sure, but it really seems like I've hit on something when the idle smooths out so dramatically when there's propane introduced near the front cylinder (and there only).
Quote from: liquidsmile on June 01, 2011, 06:58:57 PM
Reply #19 on:
June 01, 2011, 10:48:57 PM »
You only proved that cylinder is running lean by that test. Could be a vacuum leak, could be a fuel problem (like a bad injector). Put a smaller, more flexible hose on that propane torch so you can target different areas like intake runner gaskets and throttle bodies. Keep in mind some leakage at the throttle shafts is normal. Or you could go to an automotive shop with a smoke machine and ask them to hook it up.
normalcyispasse
Reply #20 on:
June 02, 2011, 06:20:34 AM »
Quote from: howie on June 01, 2011, 10:48:57 PM
Can do. I know the injectors are good, though; they were cleaned and flow-tested just last week, and both passed quite well. Since the problem is with the front cylinder, I swapped the injectors F-R to see if the problem would change; it didn't, which leads me to believe it's not an injector issue.
I'll do some more work with the hose today.
Reply #21 on:
June 02, 2011, 07:29:58 AM »
Quote from: normalcyispasse on March 17, 2011, 11:58:47 AM
Valve clearances are as follows (in crap-ass form because I can't get good table formatting to work):
Horizontal cylinder valves (Control values)
Intake Exhaust
L R L R
Openers 0.11 (.05-.18) 0.11 (.05-.18) 0.2 (.05-.23) 0.2 (.05-.23)
Closers 0.2 (.13-.25) 0.22 (.13-.25) 0.16 (.08-.20) 0.12 (.08-.20)
Vertical cylinder valves
Intake Exhaust
L R L R
Openers 0.13 (.05-.18) 0.13 (.05-.18) 0.22 (.05-.23) 0.21 (.05-.23)
Closers 0.22 (.13-.25) 0.23 (.13-.25) 0.18 (.08-.20) 0.18 (.08-.20)
~~SNIP~~
I work in inches, so, converted:
Intake Exhaust
L R L R
Openers .004 .004 .008 .008
Closers .008 .009 .006 .005
Intake Exhaust
L R L R
Openers .005 .005 .009 .008
Closers .009 .009 .007 .007
I don't have my database at hand, but IIRC, those clearances don't look good.
normalcyispasse
Reply #22 on:
June 02, 2011, 07:31:55 AM »
According to the shop manual, all valves are within control tolerances (in the original chart, the values in parentheses).
Quote from: Speeddog on June 02, 2011, 07:29:58 AM
Intake Exhaust
L R L R
Intake Exhaust
L R L R
Reply #23 on:
June 02, 2011, 07:47:53 AM »
Quote from: normalcyispasse on June 02, 2011, 07:31:55 AM
Yes.
Reply #24 on:
June 02, 2011, 10:46:23 AM »
For reference, S4 service manual says:
Intake openers: 0.10-0.15, limit of 0.05 (.004"-.006", limit .002")
Exhaust openers: 0.15 -0.20, limit of 0.05 (.006"-.008", limit .002")
Closers: 0.05-0.10, limit of 0.20 (.002"-.004", limit .008")
I'd go for within the ranges, so IO 0.10-0.15, EO 0.15-0.20, and Closers 0.05-0.10
In general, Ducs don't run well at idle and part throttle with loose closers.
normalcyispasse
Reply #25 on:
June 02, 2011, 10:59:39 AM »
Are you looking at the S4 (916) manual or the S4R (996) manual? From the S4R service manual:
Opener specs:
Intake:
Nominal: .20
In Operation: .18-.23
Check: .05-.18
Exhaust:
Nominal: .20
In Operation: .13-.18
Check: .05-.23
Closers:
Intake:
Nominal: .15
Check: .13-.25
Exhaust:
Nominal: .15
In Operation: .08-.13
Check: .08-.20
Quote from: Speeddog on June 02, 2011, 10:46:23 AM
normalcyispasse
Reply #26 on:
June 02, 2011, 11:15:41 AM »
Here's some info from LT Synder's Ducati Desmoquattro Maintenance and Modification Guide, 3rd Edition:
Ducati 4-valve Recommended Clearances (pre-tesastretta)
Recommended:
Intake:
Openers: .002"-.007" (.05-.18mm)
Closers: .006"-.010" (.15-.25mm)
Exhaust:
Openers: .002"-.009" (.05-.23mm)
Closers: .004"-.008" (.10-.20mm)
I sure hope I don't need to get in there again and adjust valves. That's a SERIOUS pain in the butt. Besides, that also doesn't explain the "sucking" noise on the front cylinder or the flash riding up the throttle body as shown in the video.
Reply #27 on:
June 02, 2011, 11:59:26 AM »
Clarifying the LT Snyder table, he has a column on the right "My Setting":
Ducati Recommended My Setting
Intake:
Openers: .002"-.007" (.05-.18mm) .004" (.1mm)
Closers: .006"-.010" (.15-.25mm) .004" (.1mm)
Exhaust:
Openers: .002"-.009" (.05-.23mm) .006" (.15mm)
Closers: .004"-.008" (.10-.20mm) .004" (.1mm)
I'm fully aware of how much work it is to do 4V clearances.
The problem may exist elsewhere, but there's baselines that have to be correct so you can eliminate them as suspects.
normalcyispasse
Reply #28 on:
June 02, 2011, 12:29:31 PM »
While it would be nice to have every valve spot-on, that's just not feasible right now. While I could see tolerances that are too tight/too loose being problematic with stumbling idle or whatnot, that wouldn't explain the flash up the throttle body and it also wouldn't explain the "tsst tsst tsst" sound either.
With none of the valves out of official Ducati spec, I just have a hard time believing that would be a factor that would have to be eliminated right away.
. . . In large part, because JESUS, Ducati, could valve work be any more difficult?
liquidsmile
Reply #29 on:
June 02, 2011, 05:32:48 PM »
Quote from: Speeddog on June 02, 2011, 11:59:26 AM
Ditto,
and from the video what you are experiencing is called a lean sneeze and it is from the TPS not being set correctly, and the throttle bodies being out of sync/carbon around the plates.
I have an 05 and had this problem.
How did you guys reset the TPS on this bike? (detailed please)
Owner of
2005 Monster S4R
