M696 Performance Information
Started by freeclimbmtb, March 14, 2011, 11:16:02 PM
I searched my old posts and couldn't find anything. tgis is the first time i think for this exhaust setup.
i think if i redlined it then it would power independent?
Kev M
Another Data point - Motorcycle Consumer New (MCN) lists the following specs in their performance guide:
~02 M620ie - 54.3 hp / 36.5 ft. lbs. 12.52 second 1/4 mile and 424 lbs wet weight
~06 M620D - 57.5 hp / 40.1 ft. lbs. 12.23 second 1/4 mile and 449 lbs wet weight
~06 M695 - 62.1 hp / 41.7 ft. lbs. 12.90 second 1/4 mile and 415 lbs wet weight
~08 M696 - 68.2 hp / 29.7 ft. lbs. 12.21 second 1/4 mile and 408 lbs wet weight
NOTE: ~ = year of test, so model year could be one earlier or later.
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Adamm0621
Quote from: Kev M on October 22, 2012, 06:52:15 AM
I wouldn't mind testing that quarter mile time...
2010 Monster 696 Dark
Kev M
FWIW, the seat of the pants review of the MCN data (based on comparing a number of models we own or have owned or demo'd that they've rated) is that it's probably pretty accurate, at least as comparative data.
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Johnny5
29.7?  That torque number has to be wrong for the 696...
Sundad - Father and Son Acoustic fusion guitar trio http://www.sundad.com
See us on Youtube -
Kev M
#20
Quote from: Johnny5 on October 23, 2012, 08:54:57 AM
Nope, don't think so. I've seen other similar reports.
It's tuned more for peaky hp and less for peaky torque.
Doesn't really surprise me.
I stand corrected  - happily so in this case.  [thumbsup]
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Kev M
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Not mine. not sure. but that similar to the dynos I've seen
Kev M
Quote from: Raux on October 23, 2012, 09:22:05 PM
Hmmm, looks like you're right and I (and MCN) stand happily corrected.
Here's another:
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
I like to use MCN's performance and specs numbers. However, I've noticed small obvious mistakes in their numbers before. For instance the weight of the 06 620Dark is probably not correct.  There is no reason for it to be that much more than the 02 620 or the 695.
Kev M
Quote from: Travman on October 24, 2012, 04:28:08 PM
Did that 02 have a single front disc and a metal tank?
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Quote from: Kev M on October 24, 2012, 06:49:28 PM
Good question, but all three of those bikes listed had two front disks. The plastic tank debuted in 2005 so if anything that 2006 should be a little lighter than the 2002 620.  The two piston front brakes also debuted in 2005 so that would drop a little weight compared to the earlier 4 piston brakes found on the earlier 620's.
Kev M
#28
Quote from: Travman on October 24, 2012, 07:14:13 PM
I'm just pointing out there may be some parts differences that we're not taking into account here (maybe different battery, different wheel, different calipers/rotors, different forks).
I guess I'm saying I have no real need to doubt that spec until I see it from another source.
That said, it's hardly important right?
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Quote from: Kev M on October 25, 2012, 06:38:34 AM
I'm just pointing out there may be some parts differences that we're not taking into account here (different battery, different wheel, different calipers/rotors, different forsk?
True.  [thumbsup]
