I make the beast with two backsed up big time
Started by Jdan, April 22, 2011, 12:07:41 PM
gr1976
Quote from: ducatiz on April 22, 2011, 06:22:56 PM
6mm gap?
that's some damn high voltage, how big of an alternator do you run?  2kW?
a flux capacitor will shoot an 8mm gap every time... ;D
Seriously though, I've had this happen a couple of times and I'm very careful of not to over tighten plugs. I thing sometimes you just get a bad casting.
MongoReturns
Haha just realized you have one of my bikes - it's .6-.7.  I go with .65; haven't changed plugs in like 5 years (NKG's).
I thought Champion was a US company.
2000Monster750Dark: cored pipes, stage2, 43t, f-18, dptach
2007 1098Red: home depot cooler guard, on sale cluch cover, on sale dp dark tall screen, ebay hugger, hand painted clutch spring caps
Jdan
.65 sounds good. Yeah, it was a bad casting. Had a hairline crack within the plug.
MongoReturns
Quote from: gr1976 on April 22, 2011, 07:10:52 PM
What are you people doing to the plugs??  Don't they test for cracks before they sell them???  Jesus if that happened on my 1098 it'd never come out - those stupid things go like 6" into holes.
Quote from: MongoReturns on April 22, 2011, 07:23:56 PM
no shit....
you'd have to pull the head and go at it from the bottom.
That would suck.
gr1976
I used to work in an auto shop and still do a lot of maintenance for friends and family. I've changed hundreds of plugs, but its only   happened two or three times. Luckily its never happened on a plug that was hard to get to (as in your 1098), but it does happen. With the millions of plugs they make I don't think they check everyone before shipment.
Quote from: gr1976 on April 22, 2011, 07:33:46 PM
<snip> With the millions of plugs they make I don't think they check everyone before shipment.
Really? ;D
gr1976
i said "THINK"... [laugh]
If this did happen on a deep hole you could probably get it out with a long thin screwdriver by twisting against the side electrode. However, I'm not sure if something like the 1098 has the clearance to allow a screwdriver that long into the spark plug hole.
MongoReturns
Quote from: gr1976 on April 22, 2011, 07:44:52 PM
Negative. I actually need to take them out to properly gap for Iridium plugs - I went with the book spec for normal pugs.  Stupid 1098-forum.  And of course I'll be thinking of this thread when I put them back in.  Definitely taking the tank off this time  [bang]
It wouldn't be fun.
Teutonics
Had that happen to me once, but on the old plug coming out (rusted/galled in place).  Getting it out was a real PITA, it was in a car in my garage and I thought I was going to have to pull the head to remove it!
Atlanta, GA - 2002 M900ie
NorDog
Friendly warning:  I use a torque wrench every time I can, but they can let you down too.
Back in the '80s I was torquing head bolts on an HD Shovelhead.  I forget the setting on the wrench (but it WAS correct) and as I continued to torque I said to myself, "Self, this seems like a LOT of torque."
About that moment the head bold snapped in two.
Fortunately it part left in the head backed right out once I got the head off and tapped it lighting with a flat tip screwdriver.
I never used that particular torque wrench again.
