February 22, 2025, 11:09:52 AM *
Pages: 1 2 [3]   Go Down
Author Topic: Monster 796 clutch conversion?  (Read 16714 times)
Curmudgeon
« Reply #30 on: January 28, 2012, 10:52:48 AM »
Wet clutches work really nicely, embrace progress  Tongue
Puzzled here as well why anyone would do this, (for a bunch of clatter and "loose nuts in a can"), when the APTC works so sweetly on my 796, at least for my taste..., and this is my 9th Ducati since 1965.  Wink Maybe (definitely) I'm getting weaker too!  Smiley Smiley Smiley
« Reply #31 on: January 28, 2012, 11:37:47 AM »
although i was on the dry clutch conversion search as well, mainly to get rid of the APTC since it tended to slip under heavy load and heat.
now that EVR has said they will do a true slipper for the small case motors.. i've decided to wait for that. NOW, can I ever afford it...
Curmudgeon
« Reply #32 on: January 28, 2012, 12:04:25 PM »
Never even had a hint of slip, so I must be getting old!  Wink Serious downshifter though and nice to have no hint of lock-up either, and that's with 10 more ft. lbs than you too.
The wet version is 2/3 the cost of the dry? Are you after this, or are you a clatter fan?  Cool http://www.motovationusa.com/mvstore/scripts/prodView.asp?idProduct=986
freeclimbmtb
From Zero Member to
« Reply #33 on: January 28, 2012, 12:23:38 PM »
I've dropped the clutch and had the revs fly up almost to redline (not intentional...one click to many in a panic) and the only time I've ever had any wheel lock was into first on a cold tire.
I want it for the look, the sound, and the history...
It's called a dual mass primary gear and it has been responsible for a 'few' heavy engine repairs.
Older small Monster's one piece gears can be fitted to avoid this issue, but it's making a really loud high pitch noise.
As for this, clearly noise isnt an issue for me, and I actually like the sound of gear whine...makes it sound like it has a roots blower  Evil
(and I didnt realize that there was a failure concern...looking into that NOW.)
2011 Monster 796 ABS
« Reply #34 on: January 28, 2012, 02:00:05 PM »
I had clutch slip pretty bad during a trip to italy, me the wife and baggage, summer heat.
Curmudgeon
« Reply #35 on: January 28, 2012, 02:43:03 PM »
Guess you can sell her on the "solution" then?  Wink That must be nearly X2 the load I'm carrying.
Oddly, during break-in I had a couple of instances of clutch "moan" at no load and low speed and RPM for no apparent reason. Disappeared after cooling down, again for no reason. Since my dealer changed the oil to his bulk Redline 15W50 Racing, vs the Shell Advance, that moan never returned. Go figure...
Why a 696 vs 796 BTW? Insurance cost in Germany? Just curious since you sometimes carry a passenger, (brave lad!)...
« Reply #36 on: January 28, 2012, 04:20:51 PM »
honestly the 696 was enough through the Alps with passenger and gear. it wasn't til the heat of Italy that I had issues.
COuld have been oil choice, so to prepare for WDW 2012, I'm going to 20w-50
BUT still, A more positive lock clutch would be better IMO. I used to have a M900 with a dry clutch and had a lot of fun with that setup, so even going with a non-slipper I wouldn't mind.
DoWorkSon
« Reply #37 on: January 28, 2012, 04:28:22 PM »
I know motowheels put out a feeler thread on a different board wondering how many would be interested in a dry clutch conversion..... Maybe if enough people email them, they will decide to do it....
2009 M696--SOLD
TitanMonsterS4R
« Reply #38 on: January 28, 2012, 04:54:17 PM »
I looked into this for my S2R800 and was quoted $2300 for parts and labor by a well respected Ducati shop in WVA. Unfortunately for that price I might as well buy an S2R1K.
Good luck with the conversion.
DTR
« Reply #39 on: January 28, 2012, 05:01:50 PM »
honestly, I hope your right...because if I rope him into a deal...then I'll have a one off!  Grin
Now that I own the bike I've decided I need another bike: an 1100s...and get my damn adjustable forks and dry clutch.  Then I'll have the best of both worlds!!!!!
There phil, fixed it for ya Wink
freeclimbmtb
From Zero Member to
« Reply #40 on: January 29, 2012, 08:20:51 PM »
Thanks evan!
Pages: 1 2 [3]   Go Up
