Installation of Monster S4R Rearsets on an M1100
Started by xplodee, April 26, 2011, 10:24:20 AM
muskrat
it's pretty cheap to powder coat them just make sure you find a reputable shop that's done bike and automotive stuff
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
DucatiTorrey
Quote from: xplodee on April 27, 2011, 05:14:25 PM
Correct, I'm on an 1100s and installed the higher bar riser from the 696/796 and now also the 1100evo.
ooooh, handlebar risers.
cool man
  - real place
xplodee
A pic of the re-locator bracket I made to hang the rear brake reservoir from:
2009 M1100s
1988 Honda Hawk GT (track)
Past Bikes:
1995 Ducati Supersport 900CR
2007 Ducati Sportclassic S1000 SE
Anchorism
Is it just me or did you change the shifter setup? Is this a way of reversing the shift pattern?
"Life's tough.  Its even tougher if your stupid!"
-2011 Ducati Monster 796
-1985 Moto Guzzi V65TT
   Knobby tires
xplodee
Quote from: Anchorism on August 18, 2012, 12:21:26 PM
Correct, I run GP shift on my monster. Pictured is how you achieve that, to run regular shift pattern just invert the linkage.
2009 M1100s
Past Bikes:
Anchorism
Quote from: xplodee on August 20, 2012, 07:49:53 AM
Im really debating whether or not i want to try it..... I think it might royally mess me up...
   Knobby tires
If you like GP shift i would recommend you go with the actual shifter isntead of just flipping it because you get a more crisp and clean response.
if you dont like it just swap it back. its a good way to test.
i love GP shift and have been running it for about 3 years now.
Barney
saw that and immediately thought the same thing...thought about ordering the gp shifter but i like this better...more concerned about what happens when I get used to this than throw a leg over the dirtbike or something ???
12 M1100EVO
09 KTM 200XC - sold. I cried.
70 Honda 450 Scrambler
Mhanis
Quote from: shift1100 on August 21, 2012, 12:33:29 PM...more concerned about what happens when I get used to this than throw a leg over the dirtbike or something ???
Then why do it?
Pete Townshend
seanster
off topic but I love my reservse (gp) shift too...I went with the "flipping the linkage" way
how do I pick which lenght to go with when I order the gp shifter? bike is M750 with aftermarket rearset.
Buy the offset one AFAIK, only SSR makes one right now. the ones with various lengths are designed for superbikes with different rearsets.
seanster
Quote from: He Man on August 21, 2012, 09:09:38 PM
I was looking at SSR, they have two variations: a "shorty" one and a regular length one with a bend...
I guess when you said offset is the one with the bend?  Cuz the shorty is just straight.
Barney
12 M1100EVO
Quote from: seanster on August 22, 2012, 05:50:34 AM
yes bend/offset, the point is that it moves it away from the inside so u dont have to pigeon toe.
the downfall is that if u go down the thing is buggered. SSR isnt exactly high quality. Their aluminum sucks.
seanster
I contacted SSR and got the measurements...shorty is 108mm and long is 133mm
Quote from: He Man on August 24, 2012, 12:51:36 PM
My rearset was designed to stick out a bit longer than normal and it was also designed to act as a slider protection so I think the foot peg will hit frist before the shifter take a hit...
anyways, thanks for you help He-man.
