April 27, 2024, 02:30:13 PM *
Pages: 1 2 3 [4]   Go Down
Author Topic: Ducati ECU Tuning Resources  (Read 57820 times)
Christian
« Reply #45 on: March 12, 2012, 12:00:54 PM »
Cool stuff! I am definitely tracking this thread and just wanted to chime in and say thanks for posting updates. I dig this stuff. Smiley
HotIce
« Reply #46 on: March 12, 2012, 06:23:31 PM »
There are a few more things happening here:
http://ducatidiag.xooit.com/t186-Siemens---Continental-ECU.htm?start=345#p9870
I was able, via an Arduino Uno plus a CAN bus shield, and custom software (which I will make available for everyone), to get CAN frames out of the DDA port.
Here's the sketch code I used to poke the Ducati CAN bus via Arduino Uno plus CAN bus shield:
https://github.com/davidel/ArduinoAVR
krista
... does she have a
ducati addict
« Reply #47 on: May 03, 2013, 03:34:07 AM »
Oh wow! subscribed
accludetuner
Jennifer Connelly's boobs give me a raging
I AM NOT A MONSTER!
« Reply #48 on: May 03, 2013, 03:39:14 AM »
Working on a device driver for my Moates Ostrich to allow RTP with the SBK ECUs. I've been slacking but hopefully I'll have a significant update soon.
I can fit massive amounts of meat in my mouth!
My 748/916/996/998 SBK parts for sale!
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #49 on: May 03, 2013, 03:50:09 AM »
 applause
I think  Undecided
 Grin
chipripper
El Borracho mas grandisimo
« Reply #50 on: May 05, 2013, 09:59:43 AM »
Thanks for sharing your code HotIce. I have been daydreaming about porting torque for android to my monster using arduino as a compatibility layer. My initial attempts involved my VDST cable and a bluetooth serial adapter. This worked for VDST on win mobile but not for torque. I would love to get an android dash/hud going that could replace my stock gauges.
John
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
Bill in OKC
S4Rs
« Reply #51 on: May 06, 2013, 10:36:37 AM »
I've been reading good things about Rexxer:
http://www.rexxer.eu/e_index.cfm
Yogi
« Reply #52 on: May 08, 2013, 05:25:59 AM »
An update on this. On the DucatiDiag Forum, Diurdac has plugged an oscilloscope  to the CAN Bus lines coming off the DDA port, and it seems it is a 500Kbps CAN Bus protocol.
Which means that IMO, with proper cable, it should be possible to plug a $20 ELM327 OBD2 tool to it, and reset the service light (plus look at the error codes, and other information published on the OBD2 layer).
Yep I can confirm this as I have done this on my 1100S using Bluetooth Elm327 (Chinese) a lead supplied by Chris (Ducatidiag) and some beta software from the same.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #53 on: May 08, 2013, 12:51:35 PM »
There are a couple of in depth Rexxer threads around here already.....
this here is some impressive looking owner development....
... and its getting mighty interesting indeed  waytogo
 popcorn
Bill in OKC
S4Rs
« Reply #54 on: May 08, 2013, 01:55:47 PM »
I figured there must have been something before I posted that but a search didn't find them.  I've been reading about them on some Guzzi discussions
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #55 on: May 08, 2013, 05:57:39 PM »
Its a saga from go to whoa but here ya go....
http://www.ducatimonsterforum.org/index.php?topic=43335.0
And another...
http://www.ducatimonsterforum.org/index.php?topic=41934.0
JackBug
« Reply #56 on: August 28, 2013, 05:53:32 PM »
Yogi,
 I had been relying on a version DucatiDiag to be released that is capable of working on the Seimens ECU that is fitted to the 696/796/1100 Monster range but with JP ceasing further development of DucatiDiag my hopes have been dashed.
Any chance of obtaining a copy of the beta software that you have used?
Regards,
John
Atom1974
« Reply #57 on: October 30, 2014, 06:32:56 AM »
What software r u using to connect and make checks?
Tks
Federico
Duc796canada
My first Ducati and road bike!
« Reply #58 on: December 28, 2014, 07:41:36 PM »
So, Im under the impression that the 2009+ Monsters can't use the Scantwin app due to connection issues? Has anyone been able to get a 4 pin connector and if so, will the app work? Thanks.
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
krista
... does she have a
ducati addict
« Reply #59 on: January 26, 2015, 09:01:19 PM »
This is currently possible with bluetooth ELM obd dongle and a safe fiat->obd connector.
Siemens ecu has CANBUS data lines (& protocol), whereas marelli ecus have historically used K-Line protocol.
Work is afoot.
Pages: 1 2 3 [4]   Go Up
