February 14, 2025, 10:50:30 AM *
Pages: 1 [2]   Go Down
Author Topic: Poorly running s4r 07'  (Read 3596 times)
badgalbetty
its never too late to be who you might have been
« Reply #15 on: May 07, 2011, 01:15:55 AM »
I know this sounds silly but what kind of spark do you have? Things I would check are : plug wires,clean plugs,coils,charging system and use the proper battery as they use a lot of amperage,check and clean battery terminals.Check that you have a good ground from the battery. 90% of electrical issues are a shitty ground.
Wish I was there to offer more stupid advice and drink all of your beer..... laughingdp best wishes.
BGB
Moronic
07 S4Rs
« Reply #16 on: May 07, 2011, 07:06:35 AM »
In case it helps, my 07S4Rs (same engine):
- usually starts within a couple of cranks, and with the throttle left alone.
- had a voltage regulator go bad, so that the battery went flat and wouldn't start the bike. For irrelevant reasons, I rode it about 50 miles like that, push starting twice (no fun!). Bike ran fine on the highway but would die immediately if revs dropped to idle levels.
Good luck with finding a fix.
TAftonomos
is without a monster :(
« Reply #17 on: May 07, 2011, 10:43:08 AM »
Is there a procedure to test the voltage regulator?
I would assume that if the battery is getting 12.5-14V while the bike is running, all is OK. ?
« Reply #18 on: May 07, 2011, 11:29:54 AM »
IIRC, Howie has linked to a charging system checkout procedure....
I think this is it:
http://www.ducatimonsterforum.org/index.php?topic=46857.msg852380#msg852380
TAftonomos
« Reply #19 on: May 07, 2011, 12:57:39 PM »
Cool, thanks!  I'll get on this and report back tomorrow with what I find.
Moronic
07 S4Rs
« Reply #20 on: May 07, 2011, 07:52:46 PM »
Telltale sign for mine was discoloured insulation on the wires coming from the regulator, obviously from overheating.
It seemed to me your bike's symptoms were different from mine. So I was thinking your problems probably were not (just) down to battery/regulator issues.
The rest could have been merely bad fuel tho.
I'm looking forward to hearing how this monster rides ...  Smiley
liquidsmile
« Reply #21 on: May 08, 2011, 04:23:51 PM »
Does one of your lines have a White Band on it?
Certified Ducati Master Technician
Owner of Ducati Greensboro - NC's only Exclusive Ducati Dealer!
2005 Monster S4R
2009 1098R Bayliss LE
-Too many options to list-
Pages: 1 [2]   Go Up
