Wanna change from reverse shifting to normal..
Started by dwu819, May 19, 2011, 02:03:01 PM
dwu819
Hi guys, I just bought a 03 999. However, the previous owner had it set up with reverse shifting that I really can't get used to it. What should I buy and install to change it back to normal? How much would it cost? It'll be better if you can post a link of the items I need to buy. I've attached a picture of how it looks now.
Thx
You have a threaded hole low on the triangular peg hanger.
That's where a shouldered bolt is going.
On the shouldered bolt, the new gear lever is going to pivot.
From under the gear lever, the linkage and rod points forward...
to where it meets the new arm which replaces the shifter you have.
I don't know, but I assume stock parts will work.
Buy new or used....
lazylightnin717
Hit that chain with some lube lovin' while you're at it. That thing looks bone dry
More pics of the bike?  [drool]
Comes a time
Says don't you see
Gotta' make it somehow
uglyducky
#3
i have a shifter rod with the arm clamps for your bike.  perfect shape. you would just need to hunt down a shifter peg.  should be pretty simple ebay or the like - $30 shipped to your door if you'd like it.
2001 996 Biposto - (sold)
tankerbutt
I may be interested in the reverse shift lever if you'd be interested in selling it after you go back to stock.  Shoot me a pm if your interested in parting with it.
