February 24, 2025, 07:18:14 AM *
Pages: 1 [2]   Go Down
Author Topic: pantah style belt covers for a monster?  (Read 7828 times)
« Reply #15 on: May 25, 2011, 05:52:20 AM »
out of interest will a pantah clutch cover fit i baby monster?
Nope.  The clutch slave on the Pantah clutch cover is actually on the right side...  Yours is on the left and uses a push-rod running through the transmission input shaft.
« Reply #16 on: May 25, 2011, 06:08:43 AM »
The old M600 and original M750 (pre1998???)  have the pantah style engine with the old style clutch slave and wet clutch.  there is no reason to swap it with a pantah though, UNLESS you wanted to upgrade to a dry clutch (which was a standard setup on the alazzurra and paso 750).  afaik, the crank shaft is the same size/spec and the engine case will take the pantah clutch cover no problem.
monster with right hand side clutch slave: (pantah style engine)
pantah dry clutch cover vented:
this mod will ONLY work on monsters that have a RIGHT HAND SIDE clutch slave as in the photo above
« Last Edit: May 25, 2011, 06:15:05 AM by ducatiz » Logged
bikepilot
« Reply #17 on: May 25, 2011, 06:59:31 AM »
That's cool, I didn't know those fit the small case monsters.  Put me down as interested in a set too  Wink
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
« Reply #18 on: May 25, 2011, 07:08:40 AM »
covers on ebay:
http://cgi.ebay.com/ebaymotors/Cagiva-Alazzura-Belt-Covers-Ducati-Pantah-_W0QQcmdZViewItemQQhashZitem3f0a39b5b4QQitemZ270754493876QQptZMotorcyclesQ5fPartsQ5fAccessories
Mike Qube
« Reply #19 on: May 26, 2011, 12:49:00 PM »
How owuld you go about upgrading to a dry clutch on one of these? I have a 97 M750, where would I find the parts for that?
zooom
« Reply #20 on: May 26, 2011, 12:51:50 PM »
How much money do you have sitting ready to spend?!?!?!
2010 KTM 990 SM-T
Mike Qube
« Reply #21 on: May 26, 2011, 12:56:46 PM »
 laughingdp I had a feeling it would be pricey! I mentioned a dry clutch conversion to someone before and they said to just buy an M900 and avoid the hassle/cost involved.
« Reply #22 on: May 26, 2011, 01:36:29 PM »
pick up the side cover, the clutch parts and the cover and bob's your uncle.. either an alazzurra 650 or a paso 750
i'd put it at about 400-600 to find good pieces...
corey
'06 Tang/Black S2R800
« Reply #23 on: May 26, 2011, 06:57:15 PM »
BTW, they only fit the small cased motors (600,620,695,750 & 800)
not necessarily.
i saw a fellow who basically angle cut the belt the cover (actually it was like an "S" curve, he did it with a scroll saw) and bolt the front half up, and the back half up, leaving an open "space" in between. it looked really slick. I will say however that i'm unsure if it was a larger case motor, or if he just routed out a slot and bolted them to a smaller motor anyway...
looked cool though.
this post is useless...
FML.
« Reply #24 on: May 26, 2011, 09:08:11 PM »
You're not crazy...
It was done by a friend of mine and that's how he got them to fit his 900...
corey
« Reply #25 on: May 27, 2011, 04:48:49 AM »
You're not crazy...
yes! memory FTW.
got a pic of that? it looked really sick, i almost picked up a set of schlong-covers to do it myself.
« Reply #26 on: May 27, 2011, 05:10:52 AM »
Nope, no pic here, but he's still on the board (occassionally....) as 'm9hundo'.
suti
« Reply #27 on: May 27, 2011, 10:00:10 AM »
Pantah style cover and Paso dry clutch:
Pages: 1 [2]   Go Up
