Problem with brakes or normal?
Started by metroplex, May 30, 2011, 09:45:43 AM
Quote from: Munch on May 31, 2011, 12:47:43 PM
Check the black plunger like thingy in  the reservoir, sometimes it flips inside out, and take up space in the reservoir...
Yeah, it is possible the diaphragm  (black plunger like thingy) extended itself.  The weep holes allow venting and are separated from the diaphragm, allowing the diaphragm to drop down as the fluid level drops, preventing moisture laden air from contacting the brake fluid.  No fluid should come out of the holes.
metroplex
The brakes felt fine after doing a road test. Thanks for all the help, it is actually pretty easy to bleed and flush the brakes - although I really really wish Ducati gave the 696 the clear plastic reservoirs for the clutch and front brakes. The metal screw-down lids are a horrible outdated design IMHO.
These aren't the droids you're looking for
thought
same issue is happening me... i guess it's time to brake flush.   [thumbsup]
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
