February 15, 2025, 07:11:15 AM
Nichols flywheel failure
Topic: Nichols flywheel failure (Read 5956 times)
muskrat
Re: Nichols flywheel failure
Reply #15 on:
June 06, 2011, 07:20:48 PM »
I'll ship it tomorrow
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Reply #16 on:
June 06, 2011, 07:42:00 PM »
Quote from: ducpainter on June 06, 2011, 05:14:32 PM
Factory is a single...no?
single with a lock bend washer
atomic410
steel horse i ride
Reply #17 on:
June 09, 2011, 12:06:15 PM »
the guy who built my race motor recomended just lighting the stock flywheel citing problems with keeping the superlight ones at the correct torque and the ul alm ones having weaker splines and didn't recomend them for racing applications. I didn't question him and just went his way and lightened my stocker. I don't understand how it could be more subject to loosing though.?
Team Atomic Racing Check us out @
www.teamatomicracing.com
Thanks to my 2011 sponsors;
Motorex, Vortex Racing, Sidi Racing, Studio 299, Dunlop, Motoprimo, Caztek, On Track 4 Him, Fix Studio
2009 Framstad Cup winner
2009, 10, & 11 CRA 5 hour endurance race winner
CRA Expert #2
ZARS track school instructor
loves ze desmodromics.
Reply #18 on:
June 09, 2011, 12:17:35 PM »
I'm not sure either. For you non carby guys, however, getting the stock flywheel lightened is way cheaper. I'm going to investigate my Nichols flywheel at next oil / belt service. I don't know of any non aluminum lighter flywheels for the newer 98-99 charging system
carbed
bikes (M/SS)
greenmonster
Reply #19 on:
June 09, 2011, 02:52:28 PM »
Quote
We have unfortunately had an issue with the Ducati Performance lightweight flywheel that makes me withdraw my recommendation of its use in the post 98 models. These models have the late alternator set up, where the flywheel is splined onto the crank. Although the lightweight flywheels are hard anodized aluminium, the alloy splines that locate on the crank may not be up to the task. One we fitted to a 996 has stripped out the splines, letting the flywheel spin around the crank. In itself, this was not a big issue, as the nut was still tight and the bits of alloy taken off can’t get out and into the engine.
http://www.bikeboy.org/flywheelducati.html
M900 -97
MTS 1100s -07
lowd239
Reply #20 on:
June 10, 2011, 07:07:08 AM »
Yea there weren't any aluminum shavings in the oil when I drained it, but the oil did have a metallic sheen to it.
Definitely should have lightened the stock flywheel instead of going the Nichols route. The extra weight savings through aluminum is certainly not worth the issues Im going through.
brad black
Reply #21 on:
June 10, 2011, 06:53:09 PM »
in hindsight the one we had fail may have been due to the nut being tightened to 190nm which was the original 996 flywheel nut spec, not the 270 they were recommending later. i think it could have been a factor, but i can't remember either way now. i think we fitted a few others and they always seemed fine. and nichols wouldn't sell them if they were going to cause them warranty hassles.
have you contacted nichols about it to see what they think? although it's a bit hard to know without specifically being able to tell them how tight the nut was, etc.
Brad The Bike Boy
Scooter-Trash
Reply #22 on:
June 10, 2011, 09:54:41 PM »
I just went with my trusted shop recommendation:
Machined flywheel = cheaper = no known failures = not any noticeable difference.
