New monster tank swelling
Started by The Bearded Duc, June 14, 2011, 06:21:31 PM
iRam
It turns out that my tank is just missing a bolt on the left mounting bracket. No swelling yet.
Ducati Monster 796
BMW R nineT
there are two rubber mounts for the tank on the sides
only the one on the right should have a bolt. that's the way it came from the factory.
I assume it's to allow some flex.
if you look at the rubber they are different for the sides also, the left is a single piece not needed a bolt, the right is a two piece needed a bolt to stay on.
edit: just spoke to a Ducati source- single bolt is to meet crash worthiness, otherwise not needed. he suggested putting on the left side one only and switch the rubber with it (ie two piece with the bolt, single piece without the bolt)
jerryz
The problem is now spreading in europe and asia, Ducati should go back to using steel tanks instead as none of my Older pre 2003 Duactis have this problem
Bishamon
Quote from: jerryz on June 18, 2011, 09:35:56 AM
Ethanol's affinity for water can cause corrosion in steel tanks, and ethanol is corrosive to aluminum.  It also dissolves fiberglass.
If we could just get rid of ethanol, everything would be fine.
2011 Monster 796
2007 Sport 1000 SE (SOLD) :(
fastwin
I just don't see ethanol going away any time soon. [bang] Gas sucks and it's getting worse. If I didn't use Sta-Bil Marine Formula none of my carbed bikes, mowers or farm equipment would run. The fuel evaporates in the float bowls really fast and gobs up the jets and passage ways like no other gasoline I have ever seen. :P
iRam
Ducati Monster 796
BMW R nineT
jerryz
i know of several new Ducatis in UK where the gas is only 5% Ethanol same as Germany  and they have swelling tanks , i have seen the problem in Thailand on 5 bukes an the gasohol here is 5% ,
The gasoline companies and governments in Europe want to up the ethanol content to 10% so the problem will only get worse ,,, a little rust in tanks from water is easier to fix than warping plastic .
also ethanol is causing massive price inflation in food as farmer take agricultural food products out of the food chain to make fuel instead its an evil thing all round .
bdub
Farmers are just trying to make as living. They don't choose where the corn goes
2005 900ie
now with mivv s'
Y2K  M900 ie  totaled  10/09/08
hillbillypolack
Neat!  Ducati sure as hell shot themselves in the foot on this one. Any other OEM would have made tanks to meet the fuel components of a specific region. Ducati, well, not so much. Then, fight a lawsuit that points out that oversight.
So, their hole keeps getting deeper it seems. Karma.
This might sound extreme, but I see this financially making a big dent in the Company. Or worse. And it certainly won't do much to promote loyalty and returning buyers. No matter how great the bikes look.
Can you document this?  I've been keeping track by posting on several boards in Italy and UK, but that's the extent of my language abilities.
Statler
technical tank talk = good for riding community.
ethanol political talk = locked threads.
The Bearded Duc
Quote from: Statler on June 19, 2011, 10:59:52 AM
Yeah, c'mon guys don't get my thread locked.
I started this topic because I wanted information on possible issues, including tank swelling, with the new monsters. I couldn't care less where the farmer's corn is going.
If the tank material hasn't been fixed yet than that answers that question. Does anyone else have any other problems or praises for the new monsters?
2001 M750 - Sold
hillbillypolack
Then I really hate to point out the obvious, but there is a sticky at the top of this forum about your issue specifically.  And, there's another thread that's coming in over 100 pages to date.
So . . . if you have any questions or concerns, you might see some that might have been answered. .
For the newer model Monsters, I honestly don't yet know.  Perhaps because they haven't been in service as long.  But if they are made of the same material.  Well, you can hypothesize from there.
The Bearded Duc
Quote from: hillbillypolack on June 19, 2011, 07:44:22 PM
I'm already aware of the "plastic tank problems" thread.
And the "new" monsters have been in service for 3 years already, plenty of time for things to go wrong if they're gonna.
2001 M750 - Sold
northerncalguy
With respect to the tank, I don't see crazy swelling like some of the posts in the other tank threads. What I've noticed is that it's slightly left of center and just beneath the top tank piece, I see some exposed edges of the tank panels right below the circular portion of that top tank piece. Hard to describe, I'll take pix later. I am going to the dealer today to have a quick check up will report back what I hear.
Other than that the performs awesome mechanically and looks amazing, the tank shouldn't stop you from buying, IMHO.
