Buying a new 2012 monster evo....
Started by Mugen939, June 21, 2011, 03:39:11 PM
lucien
Quote from: Narflar on August 07, 2011, 05:52:54 AM
I'm going off memory here because I've only screwed around with it once.  I think once you get to the DTC settings you have to hold the selector down until the number either changes or flashes.  Then you can cycle through the different settings.  If anything, it's in the manual  :P
That's what I thought too but it doesn't seem to do anything. Can't find anything out there in webland either. Any owners know?
Narflar
#31
Quote from: lucien on August 07, 2011, 09:35:05 AM
I just went down and fiddled with it.  Press up to get to the menu.  Cycle to the DTC setting.  There is one for DTC on off and one for the DTC level.  Hold down for 5 seconds.  Then it will let you change your setting.  Cycle through 1-4 and when you get the one you want hold down for 5 seconds.  Hold up for 5 seconds to exit the menu.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
