January 06, 2025, 07:16:04 PM
First things to do?
Topic: First things to do? (Read 6102 times)
Re: First things to do?
Reply #15 on:
June 17, 2008, 03:33:28 PM »
Quote from: someguy on June 17, 2008, 03:24:24 PM
2 years on the belts, unless I read the OP wrong....
Well, '05 S4R, most likely produced in late '04.
About 3 1/2 years or so.
ScottRNelson
Mr. Dual Sport Rider
Reply #16 on:
June 17, 2008, 03:34:23 PM »
If the bike has sat for two full years without running, it's still dangerous to run without new belts.
You can get away with three years if the engine is run regularly, like never sitting for a month or longer.
hyphen
The Resident Ninja
Reply #17 on:
June 17, 2008, 04:25:32 PM »
Update:
My friend who works at Pro Italia is getting me an oil filter, a set of belts, and crushwater (dunno what that is) today and is going to do some maintenance on the thing Saturday after he gets off work. I'll be borrowing his ramp and tie downs as well (i have a truck). Thanks for the advice, folks. He agreed that it could potentially be an issue and that those things should be addressed before I do any serious riding.
Omnipotent Potentate
Personal Pretext
Reply #18 on:
June 17, 2008, 04:30:59 PM »
Quote from: hyphen on June 17, 2008, 04:25:32 PM
...could potentially be an issue and that those things should be addressed before I do
any
riding.
Fixed it for ya
The crush washer is an soft metal washer, usually aluminum or copper used to help seal fittings, drain plugs, etc. They are supposed to be single use items - so each time you drain the oil, you would replace the drain plug crush washer before your reseat the plug.
There's also one on the oil pump filter screen, oh yeah and the little ones on all your brake fittings.
Last Edit: June 17, 2008, 05:49:53 PM by yuu
hyphen
The Resident Ninja
Reply #19 on:
June 17, 2008, 04:37:56 PM »
Well he says the chances of the belts snapping on my way home are low if I ride very conservatively. But I'd rather not risk it.
Ohmic
Reply #20 on:
June 17, 2008, 04:39:14 PM »
And don't forget to post pictures of your ride when you get it. We here at DMF can't get enough of naked....
... Ducs
'It's NOT a Harley... It's a Ducati!'
Bike#1: 2002 Ducati MH900e #1801
Bike#2: 2006 Ducati Monster S2R1000
Bike#3: 2006 Ducati Sport1000
Bike#4: 2008 Ducati HyperMotard 1100
Reply #21 on:
June 17, 2008, 05:52:30 PM »
Excellent news!
Like I said upthread, it is probably only a small chance of failure, but that failure is catastophically expensive if it happens. I think you've done the right thing.
big
my personal website
my less personal (I'd stop well short of calling it "professional") web site
Cucciolo
Reply #22 on:
June 17, 2008, 06:20:27 PM »
How difficult is for the tech to change the 2 belts? I mean should he charge 1 hour of labor or Half hour? Each belt is like 80 bucks ? I will ask for this to be done tomorrow on my S4R..
Last Edit: June 17, 2008, 06:28:30 PM by julianista
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
Reply #23 on:
June 17, 2008, 06:37:58 PM »
You're friend is a good one, keep him and listen...
as to the Ducati mechanic that stated it's 'practically a new bike' - he's an idiot - let's not beat round the bush - there isn't a single piece of Ducati literature that doesn't state the 2 year rule for belts.
He is either being lazy or trying to save you money - but as the wise ones have pointed out - blowing the motor and having the $120 in your wallet isn't really 'saving' you anything.
Complete trust in your machinery is priceless and an important step in becoming a good rider (so I've heard!)
enjoy!
hyphen
The Resident Ninja
Reply #24 on:
June 17, 2008, 06:56:07 PM »
Yeah, the discount prices on parts don't hurt either
Reply #25 on:
June 17, 2008, 07:04:19 PM »
Quote from: julianista on June 17, 2008, 06:20:27 PM
Just changing the belts? _I_ can do that in under an hour, so I'd hope a pro would be well under an hour. Normally though, you'd be checking the valve clearances at the same time (having the belts off is a great way to make sure you've got tight-but-not-too-tight closer clearances) - I'd normally expect to be able to comfortably do belts and clearance _checks_ in less than 2 hours. If any shims need changing though, the time goes up again (I usually budget an afternoon if I'm removing or replacing shims).
big
my personal website
Cucciolo
Reply #26 on:
June 17, 2008, 07:09:54 PM »
Quote from: bigiain on June 17, 2008, 07:04:19 PM
big
THanks..
My bike is at the shop to have the clutch replaced. I might as well have the tech do the belts and if you say that checking valve clearance is easy at that point, then I will have him do that as well. I wonder what my bill for labor will be to do all this??
hyphen
The Resident Ninja
Reply #27 on:
June 17, 2008, 07:48:36 PM »
Quote from: julianista on June 17, 2008, 07:09:54 PM
THanks..
they'll probably tack on an extra 2 hours worth of labor just for the belts and valve clearances. i think ducati on average charges around 100 and some odd dollars per hour.
Reply #28 on:
June 17, 2008, 08:01:49 PM »
Quote from: hyphen on June 17, 2008, 07:48:36 PM
Changing belts and checking valve clearances on a 4V Monster is more than a 2 hour job.
With the belts off, you can spin the cams and confirm nothing's binding, and it's only a minute more than just changing the belts.
Actually measuring all 16 clearances takes a good bit longer.
Reply #29 on:
June 17, 2008, 08:25:01 PM »
Quote from: Speeddog on June 17, 2008, 08:01:49 PM
Ahh yeah, sorry, I missed that...
Yeah, 4 valve motors are (I'm told, never had to do one myself) quite a lot more hassle to check and shim than 2 valvers like mine... Ignore my valve clearance time estimates
I know at least two people who pull the heads of their 748's to do the valve clearances...
bog
my personal website
