So I have embarked on upgrading the suspension on my S2R 800.
I have been reading the forums a lot to get up to speed, and thought I might
recap on what I have found, and maybe people can clarify, pitch in etc.
(A lot of this is from bergdoerfer, who sold me many of the parts)
Forks:
So the standard forks on the S2R 1k on "ok" or "acceptible", but the S2R 800 are just plain bottom of the line.
Options
1. New springs and fluid to adjust for weight.
2. Send OEM forks to get fitted for cartridges (~$1000)
http://www.gpsuspension.com/ Word is Ohlins does this directly as well.
Comments? Pros? Cons?
3. Transplant S2R 1k forks.
Nicer, slightly more adjustable, but rare.
Probably not worth it.
4. Transplant '05 S4R forks with linear springs and good valving.
Much nicer. Rather rare.
5. Transplant Showa forks from a Ducati SBK bike
Namely: 748, 916, 996, 998, ST2, ST3, ST4 (more?)
A little tall, fully adjustable, good valving and fairly common on ebay right now.
So the salient details for SBK swap seem to be:
1. Monster forks are 50mm wide at the top and 54mm at the bottom but SBK forks are 53mm top/bottom.
Bore out the stock top triple, and shim the bottom triple to make it fit.
(or buy a fancy aftermarket triple(s))
2. SBK forks are longer, so be prepared to add risers to your handlebars, or go for clipons,
to keep the necessary geometry
3. The Caliper mounts on S2R have 65mm between bolts.
Many/Most//All (?) SBK forks have 65mm spacing so existing calipers will work.
4. Steering head bearings might be a good idea.
5. Springs might need to be replaced based on your weight?
(resources to figure that out?)
6. Might be a good idea to rebuild (have rebuilt) your forks with new fluid / seals
(is this true?)
Front Brakes:
Front brakes are not terrible, but could be nicer.
Again, basically anything from the 748, 916, 996, 998, etc
- Brembo four piston gold calipers from an SBK are a good idea.
Good idea to stick with 65mm bolt spacing like original.
- New rotors
320mm x 5mm, and 10mm offset with 6-bolt pattern,
- New brake lines to make it all work.
http://spieglerusa.com/ http://www.galferusa.com Anyone know the lengths already?
What banjo configurations?
ShockRear Shock is also rather crap.
Options (so far):
- Ebay an Ohlins Shock from 748 916 996 998.
These have a resevoir on the side and may require "making room" under your bike.
- Traxxion Dynamics Replacement ($700 - $1500)
- worksperformance.com/html/street.html
- Ohlins (Something that will just drop in?)
- Am I missing anything?
