School me on tractors
Started by Popeye the Sailor, July 28, 2011, 07:54:32 AM
Quote from: ducpainter on July 29, 2011, 01:52:49 PM
What's the scotch for?
To make you feel better when...
you bury the two wheel drive tractor in the mud, break the 4 wheel drive trying to pull it out, and then tipping the excavator over trying to pull the whole mess? ;D
I have a plan:
Nissan Patrol test drive and Russian Monster Tracktors
zooom
when he could have avoided the whole mess with a small slew of well timed explosive charges to do the work in less time with less effort
2010 KTM 990 SM-T
Quote from: ducpainter on July 29, 2011, 02:08:58 PM
nothing good can come of this.
It's about time I do something stupid. I think 2wd, 40's vintage, and any tools I can find that'll fit. If nothing else-the actual useable stuff costs legitimate money.
Quote from: MrIncredible on July 29, 2011, 02:11:31 PM
Wanna buy my Massey...
You can have all the ambiance you want...
and mosquito control to boot.
Quote from: ducpainter on July 29, 2011, 02:29:32 PM
Only if you deliver it.
Paint it flat black first though.
Ddan
That would take away from the ambiance.  Maybe a couple coats of clear over the patina?
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: MrIncredible on July 29, 2011, 02:59:22 PM
Steve will do it when it arrives. ;D
I know how you love flat black.
The patina comes out of the exhaust.
I'm sort of looking for something like Nate's, with less rust. Can I run implements off it alright?
Quote from: MrIncredible on July 29, 2011, 03:10:26 PM
My tractor runs everything I put on it.
It sucks for bucket work. I do have a manure bucket for it, but I recently removed the last part of the framework.
My Massey has a high/low range transmission and barely goes slow enough with the tiller. The compact tractors of today are better for that as they have even lower ranges in the transmission.
For a rotary mower or woodsplitter, or any draft implement...harrows or the like it's just the ticket. It would also be pretty good with a tedder or rake.
It's a little tired to run a baler.
Kaveh
See that's what I was doing with the Kubota. Scraping the topsoil off for a driveway. The heavier ones work better. The light ones, not so much. plus you get better traction with tracks.
Now here's an old D4 that does a lot of work.
CAT D4
Quote from: D Paoli on July 30, 2011, 02:36:14 AM
CAT D4
It helps if you run a roto tiller over the loam first if you're using a tractor mounted bucket.
