February 20, 2025, 06:29:35 PM *
Pages: 1 [2]   Go Down
Author Topic: 14T sprocket install going wrong.  (Read 5806 times)
hillbillypolack
« Reply #15 on: August 29, 2011, 05:58:25 PM »
Still waiting for those pics.
brad black
« Reply #16 on: August 31, 2011, 06:15:59 PM »
the clutch slave screws often do that, as said they just stick in there.  i usually drill the head off, as the friction causing the issue is between the head and slave.  never had a headless screw left that i couldn't screw out with my fingers (be careful not to cut yourself tho).  but if some idiot has loctited them in or they're corroded you could be screwed.  anti seize doesn't seem to help - i've had to drill out clutch slave screws i know i've lubed and torqued previously.
i try to stay away from ezyout things.  left hand drills work well too.
don't pound the screw heads too hard with a hammer either - altho the cover is supported behind the clutch slave it's still only a fairly thin casting.
make sure the cover screw behind the slave is tight while you have it off too - if they're loose they can leak oil out of the pushrod.
Brad The Bike Boy
http://www.bikeboy.org
2-Skinny
Head Mechanic, Technical and Research Consultant
Measure Twice, Cut Thrice...at least...
« Reply #17 on: August 31, 2011, 07:07:10 PM »
...but if some idiot has loctited them in or they're corroded you could be screwed...
Pun intended...?
newbie_mike
« Reply #18 on: September 19, 2011, 10:12:13 PM »
Its been a few weeks but I finally had some time off to address this again.
I took Pitbull's suggestion and I have to give him mad props. bow down I dremmeled a small slot in one side of the head and took a screwdriver + hammer to it.   It took a little over half-dozen hits but it finally gave way.
I had a few minutes if satisfied elation that I wasnt completely useless!   chug
Sadly, it was not to last.  I loosened the chain, took the sprocket off and just for kicks, counted the teeth.
1,2,3....13,14?? hmm, must have miscounted.  I put it up against the new 14t sprocket I bought, and what do you know - they were identical.
I must mention that I bought the bike used - so I was riding on the 14T mod the entire time without knowing.  FML   bang head
 bang head bang head bang head bang head
I really hope someone out there is laughing at my idiocracy....  bleh
s2r 800 dark  05
DarkStaR
« Reply #19 on: September 19, 2011, 10:28:25 PM »
 Smiley
danaid
« Reply #20 on: September 20, 2011, 08:31:09 PM »
 Grin
 I would be lying if I said I never had a similar moment.
11' 1198SP  Black
09' 1100S    Red
« Reply #21 on: September 21, 2011, 03:46:03 AM »
 laughingdp applause
Charlief
« Reply #22 on: September 25, 2011, 03:59:19 AM »
I have to admit that I actually butted out laughing when I read that!
Ya we've all done something like that.
Teutonics
'02 900ie
« Reply #23 on: September 30, 2011, 08:59:42 AM »
 laughingdp
I'm definitely laughing with you, not at you.  BTDT!
Atlanta, GA - 2002 M900ie
Pages: 1 [2]   Go Up
