February 20, 2025, 08:45:47 PM *
Author Topic: Bar end removal  (Read 1240 times)
csorin
« on: August 28, 2011, 01:43:41 PM »
Hey guys,
I'm trying to remove the stock, plastic bar ends from my Speedymoto clip-ons.  How tough are these things supposed to be to remove?  I'm having a hell of a time.
JimmyTheDriver
« Reply #1 on: August 29, 2011, 09:28:26 AM »
They aren't bad with a vise-grips.  Just plastic plugs.  I put a towel over the plug to reduce damage to it, clamped the vise-grips on, and yanked around a bit.  It will come out.
-Jimmy
Omnipotent Potentate
Personal Pretext
« Reply #2 on: August 29, 2011, 10:03:47 AM »
If you want to take a minute vs. 10 seconds, just slip a blade, even a putty knife one will do, into the seam between the plug and bar. Wiggle the blade, and work around. Soon you'll have enough of the plug out to pull with a bare hand. Easy, and no chance of damage for anything
Artful
I'm glad they make pills for my
« Reply #3 on: August 29, 2011, 10:36:22 AM »
Take your pick! Works every time.
csorin
« Reply #4 on: August 29, 2011, 12:13:44 PM »
Why can I not come up with the easy solutions? drool
csorin
« Reply #5 on: September 01, 2011, 10:59:23 PM »
This proved to be quite impossible with the Speedymoto bars.  The nylon plug is flush fit, has no give, and is incredibly hard.  I made more progress cutting into the metal bar than the nylon plug.  Needless to say I had made a mess of things, and was practicing some serious anger management.
So, when hand tools fail, the power tools come out and play.  The plug met the business end of my DeWalt corded drill.  I drilled a hole axially, through the center of the plug towards the controls, then drilled another hole completely through the plug, perpendicular to the first.  Slid a screwdriver through the hole and twisted the bar end off.  Great success.
