February 11, 2025, 07:15:27 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Thanks Ducati Monster Forum!  (Read 9461 times)
mrpetebojangles
« Reply #15 on: September 13, 2011, 05:51:19 PM »
Cool, I'll be ordering some of those grip puppies soon. Thanks for the advice. Do most not chop the tail? I really don't mind the tail, but a lot of people I've been talking to are under the impression it would look "cooler". Also, I guess the 14 tooth sprocket is a very common mod it seems. Are there any cons to going to that from the stock setup. The 15 tooth sprocket is simply quieter and that's why Ducati went with the 15? Or that's what I've gathered from searching the forums. On a positive note, I have not stalled the bike since yesterday and am not really having trouble in 1st. It does feel a bit sluggish in 1st as someone mentioned earlier.
thought
Everyone needs a
« Reply #16 on: September 13, 2011, 06:06:57 PM »
commonly accepted reason that ducati went with 15t is for the emissions.  the 14t will make low end response better as you'll just be around 400 rpm higher in every gear.  it also makes the cruising speed (i.e. above 4k rpm) to be a lot more reasonable for the us.  right now on my 796 with a 15t sprocket, cruising speed is around 70+ mph in 6th gear.
getting a tail tidy does make the bike look a lot cleaner, but you'll get used to water and gravel being thrown into your seat.  look up the evotech tail tidy, it's the best one out there.
and congrats on the bike, you'll have a lot of fun Wink
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
Curmudgeon
« Reply #17 on: September 13, 2011, 06:25:09 PM »
Thanks for the report. At least for a newbee, you are making the right noises. Others above have given good advice. Do that 14T at the first service. The 696 cries for it and I fitted one to my 796 after riding a demo 696. Thank us later; the bike is hugely overgeared out of the box for EC noise and emissions. Leave the tail unless you want a black stripe up your backside or care more about appearance than practicality.
6000 until 600 miles is good. Keep it over 4000 most of the time and shift up and down a lot, varying the load. The bike will get better and better as it loosens up. Learn to smoothly match revs with the throttle and downshift to slow down and to carry the right revs through a turn. Ducatis are torquey and this will give you the best control. Downshift early.  Wink Also learn to use one or two fingers on the front brake and learn to lightly tap the rear to tighten your line through a turn when necessary.
Grip Puppies might be a good idea for those long fingers and glove fit is important too. No doubt you DO have a bit of a "death grip". Just relax but don't let your mind wander.
Figure $200 - $300 depending on your location for the first service. It's a glorified oil and filter change but Ducati wants them to plug it into the computer and do some diagnostics. They may also adjust the chain if necessary and generally look it over.
NOW..., here's the best advice I can give you: Find two or three skilled, mature riders to follow on some longer rides and tell them to chill and keep you in sight. You may have great coordination and decent skills yourself, but watch what these guys do, and when and why. There is a reason why they are still alive. You will learn traffic strategies and how to best avoid "situations". You may also learn some better lines. Learn to ride in staggered formation. All this will hugely accelerate your learning curve.
Most of all, have fun!
Adamm0621
« Reply #18 on: September 14, 2011, 05:11:21 AM »
The first service is actually a good idea (and a good time to do any small mods).  It turns out that my chain was really loose (might have been due to the sprocket change).  I also had them install my CF Termis that day.  So essentially your bike gets a checkup, and if there's anything else you want done, you can kill two birds with one trip to the dealership.
I did the 14 tooth sprocket change before I even brought the bike home (the 696 isn't my first monster).  I also had the tail chopped beforehand as well.  It looks much better, and a little rain/mud never hurt anything.
Another small, simple mod you might want to look into is putting some frame sliders on the bike.  This could save you a decent amount of money if you ever have a low speed drop, which is typical among new riders (ask me how I know).
2010 Monster 696 Dark
mrpetebojangles
« Reply #19 on: September 15, 2011, 05:56:05 PM »
Took the bike up to Virginia City today, the city sits atop a mountain and is an old mining town from the 1800s. Lots of curvy mountain roads to get up there. The bike performed beautifully up the roads and I let out a couple roars of excitement into my helmet as it was such an amazing experience. The dipping into the turns, the smooth and responsive fuel-injected acceleration out of them, what a blast. My skills seem to be improving with every second I spend on the bike, I'm doing a bit of a better job easing my grip, but my wrists still get sore, maybe I'm putting too much weight on the handlebars idk, or my hands just aren't acclimated to riding a bike yet. My tall legs and mainly my knees finally felt the strain of the locked bent position after about 2 hours or riding, but after a bit of walking around and a glass of ice water I was reading to head back down the mountain. I definitely plan on doing the 14T Sprocket on my first service visit. Is that a part that I order myself, or do I have my local dealership place the order for me? Any idea what one might charge for that and for installation? One thing I've been noticing is that during times of deceleration, or going over some bumps, the bike has a knack of really sliding my butt down the seat and my crotch into the tank, in turns really tightening my knees and bringing my head up high away from my mirrors and my head over my digital panel. Any tips on how to maintain a more comfortable sitting position. It really hasn't been a huge problem, just puts my knees at more of a bend than I'd like. I'm still getting such a kick out of people commenting on my bike. People seem to really like the looks of it, as do I of course. It's also nice when someone asks what kind of bike you got and you answer with the first word being ducati. It seems to have a tendency of making people's ears perk up and smile. Anyways, fun fun stuff. Those turns earlier today was a religious experience, everything felt so tight and enjoyable. I've managed to clock ~300 miles on my bike so far and I've only had it for a few days and all of those days I've worked. I've been waking up early to warm up, go to work, ride on my lunch for an hour after a quick bite to eat, and for a couple hours of nighttime city driving after. Love it!!
thought
Everyone needs a
« Reply #20 on: September 15, 2011, 07:17:47 PM »
you might want to look into some techspec grip pads if you're having issues sliding forward.  it'll give you a lot better grip on your tank so you dont slide forward as much.
have you adjusted your levers down yet?  that might be the issues with your wrist pain.  you'll want to adjust them down so you can extend your fingers straight when you're in the riding position.  this will keep your wrist from being in an unnnatural position when you're using the brake and clutch.  i had really bad wrist pain until i found out that tip.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
Curmudgeon
« Reply #21 on: September 15, 2011, 08:51:29 PM »
Presume you are following this thread? http://www.ducatimonsterforum.org/index.php?topic=51734.0 The Rizoma bar has a bit of rise and a better wrist angle with more sweep.
Consider a taller Sargent seat. They are also a bit flatter. http://www.sargentcycle.com/ducws6961000.htm It would also unbend your knees a bit as it's slightly taller.
The 14T should be < $40- plus labor. Any decent Ducati dealer will stock them. I also have Tech Spec pads. Going slow through town you can grip the faux tank with your knees to relieve the pressure on your hands.
Have the dealer adjust the preload on the shock for your weight. It's set up from the factory for a light rider PLUS a light passenger. If it bucks, you probably have too much preload.
Glad you are having a blast! Remember what they teach new single-engine pilots. Most accidents occur between 250 - 500 hours of flight time. So definitely enjoy breaking in the bike but don't become overconfident..., and concentrate on learning road craft.
Have Fun!
mrpetebojangles
« Reply #22 on: September 16, 2011, 07:19:54 PM »
Cool, thanks curmudgeon. I'm going to contact my local dealer and see if these things are items that can be ordered and installed. I really like the idea of the sergeant seat and bar risers to take weight off of my hands/wrists.
Curmudgeon
« Reply #23 on: September 16, 2011, 07:53:21 PM »
If your dealer is a decent Ducati dealer, he'll have a 14T on the shelf. The rest he might have to order. My dealer used Motovations USA. Follow that thread above to get the part numbers for the correct riser for a 696. If you go too high, you'll have to replace all the lines, cables, and switch gear! AND..., tell them to be careful with the routing of the stock cables with those bars. You might want to be there to position the levers and switch gear correctly when they drill the new holes on the bars for the switches. This will influence what you can see in the mirrors and also your comfort with the levers. Suggest you try positioning those downward a bit unless your 6' 7" makes this unnecessary.
This is a 796, but you can see the Sargent seat, Rizoma bars (with a 796 stock riser) and Tech Spec pads. Your seat would be a bit lower as the 796 shares the 1100 evo frame. Any questions, just ask!
ManaloEA
« Reply #24 on: September 17, 2011, 10:31:11 AM »
Very nice Curmudgeon. Now if I see around Goochland, I know to wave you down and say hi.
2011 M696
Curmudgeon
« Reply #25 on: September 17, 2011, 11:14:34 AM »
Wave fast! This bike is rough on my left shoulder under ~ 55 MPH.  Wink Suggest you keep it under 40 MPH through town though.
The bike was at "Bikes in the Bottom" at Poe's Pub for breakfast last Sunday. You're aware of that gathering in Richmond every 2nd Sunday of the month? Otherwise, any nice day BUT Sunday, give me a shout and just ride out to Powhatan for a late lunch and take this route. Not too much traffic and plenty of bends.
http://www.bing.com/maps/?v=2&cp=37.560197696845115~-77.75797835914194&lvl=11&dir=0&sty=r&rtp=pos.37.521383_-77.613517_Robious%2C%20VA___e_~pos.37.587419_-77.753121_Subletts%2C%20VA___e_~pos.37.52965899999999_-77.85362200000002_Red%20Lane%2C%20VA___e_~pos.37.54158999999999_-77.91894299999997_Powhatan%2C%20Powhatan%20Co.%2C%20VA___e_&mode=D&rtop=0~0~0~&form=LMLTCC
ManaloEA
« Reply #26 on: September 17, 2011, 08:00:20 PM »
Sorry, missed Poe's. I was in the process of shutting down my archery club in Goochland. Will try to make it out there next month.
2011 M696
justinrhenry
Super
weeeeee!!!
« Reply #27 on: September 18, 2011, 08:45:42 AM »
I have a Corbin seat on my monster.  It's much flatter and eliminates sliding into the gas tank.  It's also just more comfortable overall.
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
mrpetebojangles
« Reply #28 on: September 19, 2011, 05:22:56 PM »
I'm currently on a business trip for a couple weeks, will be a long couple weeks away from the bike! Anyways on the way home from my gf's house early on the morning of my departure, I was entering my neighborhood and braked perhaps to heavily at a stop sign and I'm not sure exactly what happened but the bike's weight shifted to the right and me being unable to correct it at the lean point it was at, I literally "laid" the bike down super gingerly. I had to walk around to the side of the bike and lifted it back up. I was surprised the strength it required to get it right side up again. The bike still looks rather perfect, no physical markings on the tank itself or rear, but there are some scratches on the rubber on the right side of the right handlebar (Bar end?)from being on the street, as well on the right handlebar's mirror plastic. I believe I perhaps grabbed the front brake too forcefully at around ~8 mph during my deceleration, the bike lost it's momentum and just tipped to the side, I had managed to get a foot down and tried initially to lift it back up, but it was too heavy as it was at a far lean and I laid it on it's side as softly as I could. Kind of a dumb mistake and I'll be easier on the front brake next time. I believe when I wanted to FULLY stop, I just grabbed too hard near the end of the stop and it tipped. It happened so fast I'm not sure. This all happened around 8 am in the morning so there weren't any cars behind or in front of me, there was a lady walking her dog from afar that I think was smiling at my mistake. I'm just happy the bike still looks alright. One thing is though, the right mirror is out of alignment now, I think the glass's angle shifted when I laid it down. I noticed that on the drive home that it was pointed inwards at my jacket I believe. I fiddled with the adjustment when I garage parked it, but I won't know if that's alright until I get home. I put nearly 600 miles on the bike in about 6 days, and my mind probably was not entirely focused on the task at hand, but at my flight departure in a couple hours. The stopping should of been more progressive, and I think it was, without the heavy squeeze near the end. I'm looking forward to my first maintenance check at 600 miles when I get back home, as I'm hoping to get my 14T installed then also. Unfortunately the snow will start soon and I won't feel comfortable to ride my bike until the ice has safely melted next spring. Thanks again for all the feedback. Any tips to think of to avoid a similar accident would be appreciated. Missing my bike hardcore and I've only been gone for a day!
Also thanks for the pic curmudgeon. Would you recommend that I start with a simple seat upgrade, to let's say a sergeant seat and then decide if I need the bar riser if my wrist pain is alleviated? What would be the downside to a flat seat? What was ducat's original intention with a sloped seat? Just a design for a smaller individual that is supposed to hug the tank with his/her knees? Thanks again for all of the feedback! Can't wait till I can jump on the bike again.
justinrhenry
Super
weeeeee!!!
« Reply #29 on: September 19, 2011, 05:34:02 PM »
what?Huh?  you dropped it already.  that's it.. you're cut from the team.
_____
2013 Honda CB1100D
2006 Honda ST1300
Pages: 1 [2] 3 4   Go Up
