eBay headlight
Started by rac3r, September 27, 2011, 11:39:45 AM
rac3r
Quote from: Jarvicious on September 30, 2011, 07:25:45 PM
I've been running an old 7" headlight off of a 79 Suzuki GS for about a year now and those can be found for a song on ebay.  Let me know when it comes in and if it's too small for the stock Monster bucket, I'd be curious to know if it would fit in the one I have and whether or not it's as bright as I'd like it to be.   Shoot me a PM when it comes in.
BTW, the Zuki bucket I have on now I think looks worlds better than the stock bucket.  You'll have to do some finish work unless you find one in really good shape (not to mention the spacing you'll need if you still have the stock headlight bracket) but they look so much cooler than stock that it's worth it to me.
Thanks for the info! I'll look into it [thumbsup]
rac3r
WASTE OF MONEY!!!!!!
It's not a sealed projector inside the headlight it's a normal reflector headlight with a lens stuck in front of it. Because of this most of the light gets reflected around and hardly any goes through the actual 'reflector'. It's going back on ebay!
I'll upload some pics once my SD card decides to work
rac3r
Pics
Comparison of stock and the new one
So called 'projector'
Stock headlight beam
New headlight with so called brighter bulb NOTE: beam is not level because I only mounted it up with tape and it's not straight
As you can see the light is all over the place!
if you use a projector, your reflector housing needs to be smooth otherwise the light scatters about everywhere. if you use a projector, the housing needs to be relatively the same size, not 3x bigger.
Someone should of told you that it wasn't going to work from the get go. .
rac3r
Quote from: He Man on October 07, 2011, 08:16:49 AM
My mistake really, have sent you a PM
BTW: you cant use a clear lens for you're stock headlight, the lens is a freshnel lens. without it the light wont focus.... and youll just end up having the ebay headlight again.
if you want a clear lens, you need a smooth reflector housing and a projector.
its an endless loop, just give in and do a proper retrofit!
sgollapalle
This is the kind of mod I had in mind. But, its a bit of fabrication work on the headlight I think...
http://www.theretrofitsource.com/product_info.php?products_id=101
Its a full projector HID kit. Not sure if the bulbs are included or if its just the conversion kit they are selling for $135...
'11 M-696
rac3r
There are plenty of projectors out there so that's not the problem it's the clear glass/lens you need which I can't make since I'm crap at making things  [laugh]
If I can find a headlight with a clear lens going cheap then I'll buy it and retrofit the projectors
racr if you're really intrested in the mod, and willing to pick up the tab, have the projctors sent to me nad ill send half the kit you're way and u can post up the other kit and ill mail it out for you, unless you have a monster mate.
rac3r
I got couple of other things to try first so I'll let you know, thanks for the offer though [beer]
