February 21, 2025, 02:22:08 PM
Please Help
FCR install-does everyone use pod filters?
Topic: FCR install-does everyone use pod filters? (Read 3958 times)
greenmonster
Re: FCR install-does everyone use pod filters?
Reply #15 on:
October 21, 2011, 04:09:06 PM »
Cheap adapters if you choose pods:
http://www.micronsystems.de/pd1085216091.htm?categoryId=79
M900 -97
MTS 1100s -07
hillbillypolack
Reply #16 on:
October 23, 2011, 06:44:47 PM »
Looks like I hadn't clearanced enough of the airbox around the throttle cable area. I took care of the gusset in side view, but it also needed some material removed in top view, as the cables at the pulley were interfering with the airbox and not allowing it to rotate fully backward.
Did that, and tugged, pulled and got the airbox over the rubber boots. Might have to clearance a bit more, but I can see it's possible to get it in place.
Should be buttoned up soon.
TAftonomos
is without a monster :(
Reply #17 on:
October 23, 2011, 08:22:21 PM »
Quote from: greenmonster on October 21, 2011, 04:09:06 PM
Whats wrong with just putting the pods directly on the FCR's ? I was planning to do just this, but if I can avoid a snag (and waiting more days for parts....) ?
MyDucParts.com
Reply #18 on:
October 23, 2011, 08:27:52 PM »
No probs if they come with the airbox adapters in the kit.
greenmonster
Reply #19 on:
October 24, 2011, 02:26:34 PM »
Like your rubber bellmouths in your airbox,
they are needed f airflow.
M900 -97
MTS 1100s -07
TAftonomos
Reply #20 on:
October 24, 2011, 05:04:48 PM »
Quote from: greenmonster on October 24, 2011, 02:26:34 PM
Thanks, but I don't follow. The pods I have slip right on the FCR's.... The link you posted isn't showing some kind of bell-mouth or velocity stack.
MyDucParts.com
hillbillypolack
Reply #21 on:
October 24, 2011, 05:50:53 PM »
I can't say from personal experience, but I heard that the airbox provided a stable air charge for the carbs and created more usable power / torque. Conversely, pods are affected easier by changing pressures under the tank and can make the carb trickier to tune.
Maybe those velocity stacks are an intermediate part that stabilizes the air charge (?) I'm just guessing here..
Reply #22 on:
October 24, 2011, 06:29:41 PM »
If the pods go straight on, then the adaptors are in place.
They bolt lnto the front of the carb. They are bellmouth like on the inside but the outside shape allows for the air jet drillways. The outside shape also allows for the air box stacks or pods for that matter, to clamp on.
They are machined alloy pieces and have a tapered, oval venturi (quite advanced), like the most modern throttle bodies. Is that what yours look like?
Last Edit: October 24, 2011, 06:36:17 PM by koko64
greenmonster
Reply #23 on:
October 25, 2011, 09:57:41 AM »
Hard to see on the Micron site, the adaptors f pods look like this:
Do you have them in your kit?
M900 -97
MTS 1100s -07
hillbillypolack
Reply #24 on:
November 07, 2011, 05:56:13 AM »
Anyone have pics of the 'split' airbox? I'm considering cutting the stock airbox from the battery box for easy install and better wire routing. I think koko mentioned it, but I didn't see any images.
Thanks in advance.
TAftonomos
Reply #25 on:
November 07, 2011, 07:30:00 PM »
Quote from: greenmonster on October 25, 2011, 09:57:41 AM
Yup. Never really noticed they are/were a separate part from the carb body casting. Pods are clamped on
MyDucParts.com
