February 24, 2025, 10:40:50 PM
Water in fuel
Topic: Water in fuel (Read 7501 times)
Re: Water in fuel
Reply #30 on:
November 20, 2011, 04:35:50 PM »
Quote from: sofadriver on November 20, 2011, 04:32:13 PM
I've never seen a gas tank that drains directly from the bottom of the tank. Fuel is always sucked from pick-up tubes that stick up 2-3" from the bottom. That allows water & gunk to settle below the good gas.
To get it out use a suction device with the suction hose end wire-tied to the end of a stick to get to the very bottom of the tank. I do this every fall on my boat. Acceleration/deceleration can cause that pool of water to spill over into the pick-up tubes. That can cause sputtering and will also form new pools of water in your float bowls.
On carby Monsters the fuel comes from a threaded fitting about 1/2" from the lowest point on the tank.
It's Italian...remember?
sofadriver
Re: Water in fuel
Reply #31 on:
November 20, 2011, 09:12:07 PM »
Quote from: ducpainter on November 20, 2011, 04:35:50 PM
Oh...........yeah...........
The theory's the same, though.
Gotta' suck out that last half inch (I had a girl tell me that once...........still don't know what she meant!
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
