February 21, 2025, 01:55:14 PM
carbon monster
Topic: carbon monster (Read 4734 times)
Re: carbon monster
Reply #15 on:
November 17, 2011, 06:44:17 AM »
A stock (ish) '93 M900 as a collector? Yeah, I can see it as I've been looking for one myself.
But, I'm a Monster nut-job so I'm already in the minority...
bikerburnout
Re: carbon monster
Reply #16 on:
November 17, 2011, 10:56:14 AM »
Quote from: greenmonster on November 17, 2011, 04:35:59 AM
http://www.ducatimonsterforum.org/index.php?topic=48398.15
looks fantastic. thnx for the link
NorDog
I don't feel like a
Re: carbon monster
Reply #17 on:
November 17, 2011, 10:58:29 AM »
http://www.hairdirect.com/hair/systems/default.aspx
bikerburnout
Re: carbon monster
Reply #18 on:
November 17, 2011, 11:04:18 AM »
i think i might have a few more years left with my hair. saying that i might just go for the comb over, its cheaper
greenmonster
Re: carbon monster
Reply #19 on:
November 17, 2011, 04:26:05 PM »
Quote
Doable and if you like the looks, go f it.
It`s your life-bike-money.
Wont add value to most people IMO.
M900 -97
MTS 1100s -07
Re: carbon monster
Reply #20 on:
November 17, 2011, 04:43:26 PM »
I agree with everything people have said. It is your bike and you should do whatever you want with it. However, I think we would be doing you a disservice by not letting you know how tacky fake carbon fiber is. I would put it in the same category as neon lights, extended swingarms, and chromed wheels.
Re: carbon monster
Reply #21 on:
November 17, 2011, 09:16:37 PM »
Quote from: Travman on November 17, 2011, 04:43:26 PM
sounds like a whole lot of people didnt get that memo!
zooom
Re: carbon monster
Reply #22 on:
November 18, 2011, 04:14:47 AM »
I personally think that the purpose for laying carbon over a steel tank is pointless...the point of carbon to me is for to reduce weight while maintaining rigidity when using it to replace metal...in this case, that isn't what you are doing, and I just don't understand why really....if it is a look thing( especially since you are being cheap,ie:not buying a carbon tank), I just think you'll end up better off just wrapping the tank in carbon look vinyl...not to mention the potential in this project for make the beast with two backsing up a perfectly good tank if things don't work out well or the way you want....maybe the answer is this, if you intend to do this no matter what, maybe find a used/dented tank off Fleabay and do it to that while your perfectly good origional stock tank sits in a bag/box on a shelf...just my .02 FWIW
2010 KTM 990 SM-T
Re: carbon monster
Reply #23 on:
November 18, 2011, 11:05:56 AM »
Are there even any sources for a real carbon fiber tank anymore for our older Monsters anymore?
Last Edit: November 18, 2011, 05:25:18 PM by Travman
Case S2R
Re: carbon monster
Reply #24 on:
November 18, 2011, 11:12:22 AM »
You have received opinions but how about practical application?
Once you wet out carbon it will slide all around your tank so you will need to hold it in place or you will never get straight lines and the weave wil be wavey.
My solution to this is pre preg, but now you have to cook your tank, so make sure it can handle the temps.
My thoughts are the outcome of this project may not be what you envision.
Now if you have composite experience, pull your tank, use it as a plug, make a 3 piece mold and do your complete tank out of carbon. Now we are talking.
Case
bikerburnout
Re: carbon monster
Reply #25 on:
November 18, 2011, 02:25:41 PM »
Quote from: Case S2R on November 18, 2011, 11:12:22 AM
now thats a job. not confident enough for that sort of project. Zooom brought a good point to the table, probs go down that road.
Case
Nomad
Re: carbon monster
Reply #26 on:
November 18, 2011, 02:52:58 PM »
Quote from: Travman on November 18, 2011, 11:05:56 AM
Are there even any sources for a real carbon fiber anymore for our older Monsters anymore?
Yep... actually i have a CF front fender from motowheels that I can't use since I swapped to SBK forks...
Re: carbon monster
Reply #27 on:
November 18, 2011, 05:26:30 PM »
Quote from: Nomad on November 18, 2011, 02:52:58 PM
Sorry I meant to say "carbon fiber tank".
Feral 859
Re: carbon monster
Reply #28 on:
November 18, 2011, 09:03:41 PM »
Quote from: Travman on November 18, 2011, 05:26:30 PM
Yep, Ducati still has them. I've one on the 859.
