July 18, 2024, 02:40:57 AM
The power of orange compels you!
89
90
91
92
163
Topic: The power of orange compels you! (Read 466756 times)
MadDuck
The anti-
Re: The power of orange compels you!
Reply #1335 on:
August 01, 2014, 02:20:08 PM »
Quote from: Speeddog on August 01, 2014, 09:58:28 AM
So he actually has bearing failures, or he's following some prescribed replacement schedule?
Do the other guys he rides with on KTM/non-KTM have the same issue?
He's having bearing failures from what he tells me and on both of the KTM's that he owns. I'll find out which models. He says the other guys with KTM's have the same issue but the Honda's & Suzuki's are fine. This guy is an experienced rider and when younger was sponsored by KTM although not on a paid, factory team.
MadDuck
The anti-
Reply #1336 on:
August 01, 2014, 02:25:59 PM »
This is happening on the 300XC and he says it happens to all the guys he rides with that have that bike. Supposed to be a big torque engine that just over powers the rear. He says that when he was racing the smaller bikes, a 125 and a two something, that there were never any issues like that.
Reply #1337 on:
August 01, 2014, 03:21:48 PM »
300cc 2-smoker?
Reply #1338 on:
August 01, 2014, 05:17:09 PM »
Odd.
Perhaps it's got some peculiar geometry that funnels grit to the seals.
Or perhaps the wheel or spacer puts too much/not enough preload on the bearings.
In a past life I did a good bit of design work on gearbox/driveline stuff.
By the time you get a shaft big enough to carry the power, even the lightest-section bearing was usually up to the job.
A typical wheel bearing has a load rating of ~2000 lbs, and you've got two.
And bearing load ratings are *really* conservative.
MadDuck
The anti-
Reply #1339 on:
August 01, 2014, 07:13:14 PM »
Quote from: DRKWNG on August 01, 2014, 03:21:48 PM
300cc 2-smoker?
Yepper.
MadDuck
The anti-
Reply #1340 on:
August 01, 2014, 07:16:19 PM »
Quote from: Speeddog on August 01, 2014, 05:17:09 PM
Odd.
I keep telling him it's because he's installing them wrong.
He says it's because they ride the ever lovin' piss out of those things!
1KDS
Reply #1341 on:
August 25, 2014, 03:56:47 PM »
I think we need a little more orange talk in here.
Just doing a simple oil change last weekend, I had a weird angle with the socket on one of the oil filter cover screws and thought that was why the screw wasn't turning in very smoothly...
I was wrong.
I was worried about snapping an easy out off in the bolt as I have done in the past so I got some left hand drill bits, center punched the broken bolt and started drilling. I was hoping that the bit would encounter some resistance and start turning the bolt out, no such luck, drilled all the way through it. I didn't have any choice now, I drilled it with a 3/32" bit and got out the easy out. Using the clutch on the lowest setting then slowly applying more and more torque with the clutch settings it finally came out.
I was so happy it came out, I wasn't sure what I was going to do next. I tapped the threaded hole in the block and put it back together with new M5 screws. Everything has somehow been much more difficult with this bike than any other bike I've had but I love the bike and am still having a blast with it.
Every bike I've ever owned.
The best kind of whore is a
Reply #1342 on:
August 25, 2014, 04:41:37 PM »
Nice job!
MadDuck
The anti-
Reply #1343 on:
August 27, 2014, 08:29:12 AM »
It's great that you love it because sometimes some bikes/cars are just that way.
rosstermyer
M1100S
Reply #1344 on:
August 27, 2014, 01:48:10 PM »
my street legal 540sx.
Reply #1345 on:
August 27, 2014, 04:38:27 PM »
Awwe yeah!
Feral 859
Reply #1346 on:
August 28, 2014, 06:34:11 AM »
Omnipotent Potentate
Personal Pretext
Reply #1347 on:
September 04, 2014, 03:45:34 AM »
Finally spotted in the wild, an 1190 ADV in downtown DC. Aside from the display ones at a show, first time I've seen one
Reply #1348 on:
September 04, 2014, 04:28:06 AM »
Just signed up for supermoto school at New York Safety Track. Only 12 spots available, taught by an AMA SM champ I haven't heard of, Corey Alexander.. Should be fun.
Personal Pretext
Reply #1349 on:
September 04, 2014, 05:02:50 AM »
Woot! Videos are demanded!
89
90
91
92
163
