August 17, 2024, 11:59:07 AM
The power of orange compels you!
20
21
22
23
163
Topic: The power of orange compels you! (Read 471595 times)
zooom
Re: The power of orange compels you!
Reply #300 on:
April 24, 2012, 07:09:44 AM »
Quote from: Monsterlover on April 24, 2012, 06:48:15 AM
You need to change your name to Sideways Panda.
only if you come up with a picture of a panda flattracking or sumo backing it in...
2010 KTM 990 SM-T
Reply #301 on:
April 24, 2012, 07:21:42 AM »
Sumo Panda
zooom
Reply #302 on:
April 24, 2012, 08:23:44 AM »
Quote from: lethe on April 24, 2012, 07:21:42 AM
Sumo Panda
insert obligatory image of Kung Fu Panda...LOL
2010 KTM 990 SM-T
Omnipotent Potentate
Personal Pretext
Reply #303 on:
April 24, 2012, 08:34:01 AM »
Sumo is japanese - Kung Fu is chinese. Bulgogi is Korean and yummy
zooom
Reply #304 on:
April 24, 2012, 11:27:37 AM »
YES, but KungFuPanda is fat like Sumo wrestler
but since you insist....here you go...SumoPanda
but if you want to be Sliding Panda...then perhaps this is the answer...
but try not to end up likes dis...
2010 KTM 990 SM-T
Personal Pretext
Reply #305 on:
April 24, 2012, 12:04:02 PM »
I think the last one might be the most appropriate
Personal Pretext
Reply #306 on:
April 27, 2012, 05:22:39 AM »
Edited with a better photo
Right is the exhaust and you can see how much more wear it's showing than it's buddy. if you look at the full resolution version you can seem more of the chatter marks on the bearing.
Last Edit: April 27, 2012, 08:30:52 AM by Slide Panda
The best kind of whore is a
Reply #307 on:
April 27, 2012, 05:33:11 AM »
Quote from: Slide Panda on April 27, 2012, 05:22:39 AM
Not the best photo - but here's the rockers
Left is the exhaust and you can see how much more wear it's showing than it's buddy.
Fixed that for you
Personal Pretext
Reply #308 on:
April 27, 2012, 05:55:54 AM »
That's what I get for trying to copy from inside my own post as opposed to jsut grabbing the image path again. Oh well.
But yes, - you can see, twice, that the exhaust is not happy. On a good note it's super simple to replace them. Hardest part was geting the air box out.
Once that's done, 4 bolts for the valve cover - which is huge and gives you easy access for top end work. Each rocker is on a big pin held in my two bolts. Take them out, use one to pull out the pin (it's threaded for it) and the rocker's out.
Super easy... just make sure you put the rocker pins back in the right way, they do have a top and bottom. Good thing is that the bolts pass through them so as long as you get the right side up you cannot misalign them. *almost* dummy proof.
rockaduc
Reply #309 on:
April 28, 2012, 12:26:06 PM »
Quote from: Slide Panda on April 27, 2012, 05:55:54 AM
Some one will come along and build a better dummy...I am usually the dummy that f*ck's up "dummy proof" designs.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
Reply #310 on:
April 29, 2012, 06:26:16 AM »
Today...
Is supermoto day.
I registered it yesterday so I can actually ride legally now.
Vs how I rode it before
Personal Pretext
Reply #311 on:
April 29, 2012, 10:22:31 AM »
Quote from: rockaduc on April 28, 2012, 12:26:06 PM
That's why I have a tech manual. heads off a lot of potential dummy moments.
Though, as good as the KTM manuals are I've found some big issues... like there is *nothing* about how to remove/service/do anything regarding the rear swing arm. Zip zero nada... a bit shocked that it's totally left out. They have how you pull the shock and it stops there.
Reply #312 on:
April 29, 2012, 11:35:17 AM »
Just stopped home for a sammich.
This bike rocks.
ROCKS!!
I bet it would still stick with the peg dragging.
Reply #313 on:
April 29, 2012, 11:44:27 AM »
Personal Pretext
Reply #314 on:
April 29, 2012, 11:47:44 AM »
Orangy wheels...
Gonna get some sliders?
20
21
22
23
163
