February 22, 2025, 11:06:09 AM
Please Help
Kickstand Switch
Topic: Kickstand Switch (Read 4627 times)
metroplex
Re: Kickstand Switch
Reply #15 on:
December 27, 2011, 07:44:15 PM »
Hmmm, my 696 stays running in Neutral with the kickstand extended. It shuts down the engine when I shift into gear. I thought this is how all motorcycles were designed (stays running in neutral regardless of the kickstand position)? I start them like I start manual cars, I keep the clutch fully depressed.
These aren't the droids you're looking for
Reply #16 on:
December 27, 2011, 11:16:08 PM »
Nope. All motorcycles in the US since 19?? had to have be equipped so you can not ride away with the sidestand down. Early Monsters came equipped with a sidestand that retracted when you took the weight off the sidestand, quickly nicknamed the Suicide Sidestand. That was replaced with the safety sidestand switch, which prevented the bike from starting or running unless the sidestand was up regardless of gear. In 2002, maybe '01 for the S4, not sure, a change was made that allowes the bike to run with the bike on the sidetand as long as the bike is neutral or the clutch is disengaged.
Reply #17 on:
December 28, 2011, 08:38:40 AM »
Quote from: howie on December 27, 2011, 11:16:08 PM
This is how my 1985 Cagiva runs. Kicker down, clutch engaged in neutral.
yamifixer
Reply #18 on:
December 28, 2011, 09:04:56 AM »
I bought a harness off of ebay that plugs right in and alows for it to start on stand but dies the second you put it in gear with stand still down. I kind of like it.
Valve Springs are EVIL
Curmudgeon
Reply #19 on:
December 28, 2011, 09:18:34 AM »
Quote from: yamifixer on December 28, 2011, 09:04:56 AM
That's the way the new Monsters work. Same on my '09 Bonneville too except that you have to pull in the clutch to engage the starter.
seanster
Wat???? Hero Member!?!?
Reply #20 on:
February 27, 2012, 08:54:44 PM »
Friends,
I have a question...I have always been able to start my bike with the kick stand down...does that mean I can remove the wire/plug leading to the kick stand?
Bike is 2000 M750
Thanks
The best kind of whore is a
Reply #21 on:
February 27, 2012, 11:07:13 PM »
$1.49 solution from radio shack I did on my 2000 M900ie
http://www.ducatimonsterforum.org/index.php?topic=280.0
seanster
Reply #22 on:
February 27, 2012, 11:19:03 PM »
Quote from: Monsterlover on February 27, 2012, 11:07:13 PM
Well i asked because....the problem is that i took off the switch from the stand...traced it to the plug....and from the plug i traced the wires to the main harness...i then cut the wires close to the harness...
I am now wondering if my bike will run....it started in neutral when the kickstand down...before i cut the wire...i think one time i accidentally had it in gear and then started the bike with kickstand down...the engine shutted off right the way.
