February 15, 2025, 06:42:45 AM
The Mercenary Monster
Topic: The Mercenary Monster (Read 20449 times)
c_rex
Quick! Into the transmogrifier!
Re: The Mercenary Monster
Reply #45 on:
September 03, 2008, 09:01:47 AM »
Quote from: DucLeone on August 27, 2008, 05:38:30 PM
about some close ups of the headligt /mounting ?
pretty please
just noticed this... I can take some pics later tonight at home but all I did was bend up some joist strapping brackets, trimmed up the ends with aviation shears (tin snips) and then smoothed out the cut edges with a bit of sandpaper. Black rattle canned them after a layer or two of primer and voila! It was pretty simple once I got the bends correct for the top brackets. 2 top/ 2 bottom, some rubber grommet thingies, some washers, some nut/bolts. Holds on like a rock and doesn't jiggle at all.
leftcoastduc
2001 S4 Senna
Reply #46 on:
September 03, 2008, 10:07:57 AM »
Hey BW & Crex both ur rides r way Kool love the headlight BW really like theindustrial look of your bike
Ordinarily he was insane, but he had lucid moments when he was merely stupid.
In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.
Celli
Ducati Codatronca
Reply #47 on:
September 06, 2008, 02:07:21 AM »
Quote from: c_rex on August 26, 2008, 06:50:53 PM
finally pulled this one off myself. credit brownwhale with the idea. made my own brackets and may fab up a cowl sometime in the future. this headlight is sooooo much brighter than the stock headlight and was pretty much a straight across wiring job, although I took the time to invent a new
solderless method of connecting the wires
as I couldn't find my flux and was too lazy to solder mostly because I suck at it.
c-rex, I LOVE IT!!!
Celli
Ducati Codatronca: Concerto Molto Vivante!
truckinduc
Reply #48 on:
September 06, 2008, 08:35:18 AM »
Celli, where did you get your headlights? Cause i have the same ones.
Celli
Ducati Codatronca
Reply #49 on:
September 06, 2008, 08:40:31 AM »
Quote from: truckinduc on September 06, 2008, 08:35:18 AM
You mean the new one? It comes from the Ducati factory in Modena. Do you have the same? Pics please!
I must say, the headlight c-rex has looks great as well!
c_rex
Reply #50 on:
September 07, 2008, 11:25:10 AM »
sorry for delay on the bracket pix. smashed my finger while building a bench and typing has been a "touchy" subject to say the least.
Anyhow- here's a picture reduced for format size. PM me if you want more angles, closer, wutevah....
Mojo S2R
. Dark Mojo .
Reply #51 on:
December 01, 2009, 04:10:03 AM »
I don't know how I missed this thread. I really like the look of that Superduke headlight. I'm on my way back stateside to spend a couple weeks at home and plan to have my MT-01 headlight installed this week. I'll post some pix as soon as I get a chance.
My bike so far...
My desktop/wallpaper
CCMHA Map
Central Cal Monsters
greenmonster
Reply #52 on:
December 01, 2009, 07:47:35 AM »
F sure a brutal Monster.
Why not also have a R6 rear wheel?
You`ll loose over 5 pounds and it can be done, I`ve dunnit.
W an alu sprocket & wavy disc, I´ve lost 2,5 kg.
M900 -97
MTS 1100s -07
flanman
Reply #53 on:
December 01, 2009, 08:12:15 AM »
Off topic... c-rex what bars are those on your bike?
NoisyDante
I am Jack's
Reply #54 on:
January 20, 2010, 01:56:29 PM »
Quote from: c_rex on August 27, 2008, 06:47:38 AM
Wiring schema before I lose the notes I made:
Ducati --> KTM
Black --> Brown
Yellow --> White
White --> Green
Yellow/Black --> Blue
I found this really helpful, thanks for posting. Also, when I got my Superduke light it was wired up with a 6 pin Molex terminal housing. I ordered new parts from Allied Electronics. It's the .093 size, not .062. Below is a link to the parts page where the housings and clips part numbers can be found should anyone want to go the route I have.
http://www.alliedelec.com/catalog/pf.aspx?FN=243.pdf
Last Edit: January 20, 2010, 02:01:15 PM by NoisyDante
'07 695 Dark - Quat-D Ex Box exhaust, gold S4 forks, Woodcraft Clipons, CRG levers, KTM headlight, Motodynamics taillight, 14t sprocket, CRG LS mirrors, flamethrower, the usual refinements. * struck down by a hippie in a Prius on September 22nd, 2010.
