Caswell Info Requested for Coating of new Tank
Started by EEL, December 22, 2011, 11:21:00 AM
Lieutenant Dan
Quote from: ducatiz on June 20, 2012, 09:49:31 AM
Like I said, the new covered tank design hides the expansion of the tank.  They can easily make the tank smaller to allow for more expansion and possible redesign the fuel pump flange so it is reinforced and can't leak.
Yes, but still. Doesn't that sound like fixing the symptoms and not the problem? That sounds like bad engineering at the school I went to.
'07 695
Quote from: C11Gidasi on June 20, 2012, 10:04:15 AM
well, engineering is only half of the picture, the bean counters have to have a say too.
i mean.. the camel was designed by engineers in committee you know.. works great... looks like shit.
The business climate in Italy being what it is...
I wonder if there are contractual issues between Ducati and Acerbis?
Betlog
When thinning, I am told that I can use lacquer thinner instead of Xylene.  Do you guys think there's any advantage to Xylene over lacquer thinner?
Quote from: Betlog on August 23, 2012, 10:43:12 AM
Yes.  Xylene is compatible with PA6 nylon.  "Lacquer thinner" is not a specific substance, it can be any number of solvents, some of which may not be compatible with PA6.
Betlog
Quote from: ducatiz on August 23, 2012, 11:00:20 AM
Thanks.  I ended up using Xylene.
Betlog
So I have the tank curing but don't know what to do with the excess Caswell that has started down the fuel flange when I drained the tank.  My plan is to trim it with an Exacto knife but am not sure how far to go.  Did you guys trim it flush to the plastic in the gas tank?  (This way, the fuel flange will sit in perfectly with the fuel flange gasket and fuel filter bits when it's re-installed.)  My other option was to trim it flush, then coat a bit of Caswell at the bottom to make sure that if gas does go past the gasket, it would not leak into the plastic.  (The problem with this is that the gasket and fuel filter bits may not sit flush when it's re-installed.)  Thoughts?
Do you have a list of solvents that are known to be incompatible?
Lacquer thinner is all organic solvents and PA6 is touted to have excellent resistance to all organic solvents.
I would think that water content of cheap thinner would be more of a concern.
FTR, I use urethane grade reducer to thin the Caswell because it specifically contains no water.
I have a chemical compatibility chart..  i can post the link later. Caswell either read my thread or figured it out too as its named in their instructions for reducing their stuff.
Here is the online version.  Select materials=Nylon and ALL for Chemicals
http://www.coleparmer.com/Chemical-Resistance
Notably, Ethanol is resistant up to 72 deg F...
Quote from: Betlog on September 05, 2012, 08:57:31 AM
Cut a small line and use a plastic scraper.  You can sand it too.  Small deviation is OK.  There is a fat o ring there.  Grease up the oring before install.
Betlog
Quote from: ducatiz on September 05, 2012, 12:21:07 PM
Thanks ducatiz.  Where do you cut the line?  What I'm getting from your post is that it is fine to just cut out the excess and make the bottom that mates to the gasket and fuel filter bits flush.  No need to re-apply the coating at the bottom of the tank.  Is that correct?  Also, what grease should I use?
Quote from: Betlog on September 05, 2012, 01:50:47 PM
I cut the line right at the corner.  You just want to make a score so when you scrape it doesn't chase into the inside of the tank.
Any gasoline resistant grease compatible with rubber.. (LOL).. I have a tub of this stuff called Krytox which IIRC is a silicone grease specifically for Orings.  You don't need much, you are just lubing the oring so it grabs and seals.  You may not even need it.  You can probably use brake assembly grease which is a silicone grease.
Betlog
Did you guys also coat the fuel filler area - both inside the tank and what is visible from the fuel door?
Quote from: Betlog on September 06, 2012, 06:54:47 PM
I use a rubber stopper that fits the filler hole almost exactly (and make sure to plug the overflow hole).
that prevents the coating from getting to the exposed part of the filler, but it coats the inside part just as any other part of the tank.
The filler nozzle isn't nylon.  I believe it is HDPE which will present a problem with adhesion over time.  I try to scrape the coating away from it.
