Iridium Spark Plugs and Cold Start - User Beware
Started by supperduc, December 28, 2011, 04:39:00 PM
What gap do you run, the .024 (0.6) or the .036 (0.9)?
metroplex
I'm running Denso IXU24 at 0.035" gap on my 2009 696. It felt like my throttle was a bit more responsive, but it did not impact cold/hot starts at all.
These aren't the droids you're looking for
Quote from: ducpainter on June 25, 2012, 02:44:08 AM
Me?
.024
Yep.  :)
The NGK plug commonly used here has a larger gap as supplied compared to the oem Champion. It's the same large gap as the iridium plug. Does the plug you use come pre gapped at .024 or do you gap it to the oem Champion spec?
I'm curious as to the different plug gaps.
Quote from: koko64 on June 25, 2012, 05:29:24 AM
Yep.  :)
I check them, but IIRC they are close to .024.
To be honest, the plugs last so long I don't really remember.
I've never fouled one
Quote from: metroplex on June 24, 2012, 05:30:34 PM
Sounds consistent with the claims made about iridium plugs and gap sizes.
I suppose some stock ignition systems, particularly on older carbed bikes, may not be up to handling the larger plug gaps required by the iridium plugs.
So effecient, high output coils and leads are probably required to support the large plug gaps, no surprise, but it might catch some people out and explain some peoples issues.
Quote from: koko64 on June 25, 2012, 05:24:34 PM
Exactly.
High output coils have always been necessary for larger plug gaps.
It does make a performance difference too.
My old 2 smokers stopped fouling plugs with better coils and Champion Gold Palladium plugs.
So DP and metroplex, what ignition set ups you guys running?
Quote from: koko64 on June 25, 2012, 05:28:33 PM
My engine is stock except for cans...slip ons, and jetting.
I put my money into suspension. ;)
BerettaMato
I bought a set before I viewed this thread always thought they were better in some way. Shows how much I don't know. I decided to try them anyway since I was having hesitating when starting. I gapped them to .036 as suggested in this tread. I also used some boot grease. She started perfectly. After a short drive felt like a little more responsive maybe. I will up date on the cold starts come fall. I did order some OEM ones just in case.
Beretta Giarratano
Boulder, Colorado
2002 Ducati 620 Monster (Currant)
2001 Honda 1800 VTX 400 miles ridden (Hated it) Sold
2002 Honda VTR1000 20,000 miles ridden (Loved it) Sold
1988 Honda NT650 62,000 miles ridden (Soul Mate) Sold Sad
1987 Yamaha YSR50 500 miles ridden (FUN) Sold
metroplex
koko64: I'm running the stock ignition coils. I tested the IXU24 Iridium plugs using the stock wires, and then with the Magnecor wires. I didn't detect a difference with the Magnecor wires.
My 696 came from the dealer with the Race ECU, Termi slip-ons, and Race air filter.
After doing a lot of trial and error during the winter when it got into the single digits, I found that the quantity of engine oil and weight of engine oil had the most impact on cold starts w/ my 696. The plugs and wires had zero effect. Too much oil apparently causes a hard start condition. Too thick of an oil makes cold starts difficult as well. Filling my motor to the bottom sight mark line with Rotella T6 made for very easy cold starts. However, the T6 would cause the clutch to slip badly during WOT speed shifts. Running M1 V-Twin 20W-50 makes cold starts/cold idling very cumbersome, but the engine performs more smoothly.
DP. Well stock plugs and smaller oem gaps make perfect sense.
Metro. It seems its all about a better burn and improved response. I like a lighter oil in winter also.
I'm running Igniteck ignitor, high output coils and fancy leads and either type of plug seems to work well with the larger gap. Only issue I've had is plugs compromised by carb flooding (and one particular brand of fuel), so losing ten bucks is better then fifty. I reckon the iridiums bounce back a little better, but if they fail I'm cursin'.
The plug color of the iridiums (on my bike) supports the theory of a bigger flame kernel and more complete combustion at least at lower revs, when compared to the regular plugs. Thats the only test I've done. I dont ever plan to dyno test it for a street bike.
I think the science regarding low rpm running, high performance ignition, and plug gap is proven.
I just ride it. ;D
BerettaMato
Beretta Giarratano
Boulder, Colorado
Quote from: ducpainter on June 25, 2012, 06:10:05 PM
I just ride it. ;D
That's pretty much it. ;)
