February 16, 2025, 04:39:58 AM
OZ monsters
WHAT DID YOU DO TO YOUR MONSTER TODAY ??????
32
33
34
35
86
Topic: WHAT DID YOU DO TO YOUR MONSTER TODAY ?????? (Read 249932 times)
Mr.S2R
Re: WHAT DID YOU DO TO YOUR MONSTER TODAY ??????
Reply #480 on:
September 01, 2012, 11:17:19 PM »
started pulling down my dry clutch as it was getting too noisy - well in my opinion. This is what the basket wear looks like and the wear on the tangs. The clutch material itself looks good which is a shame...
kyle
Reply #481 on:
September 01, 2012, 11:26:41 PM »
Looks interesting!! Mine is slipping when cold and when up in the revs also, has 45000 on the clock.. time for a barnett wet kit i think..
Mr.S2R
Reply #482 on:
September 01, 2012, 11:56:18 PM »
Quote from: kyle on September 01, 2012, 11:26:41 PM
sounds like that is possibly springs, so make sure you get a set of those also. I am sure someone with far greater technical expertise will give a better possible cause.
I have just purchase an EVR 48T basket and clutch plate set - HOWEVER, I have stated on this forum that I am anti bling, so I just like to state that this is for functionality and performance improvement, plus I am getting a nice billet open clutch cover and new EVR pressure plate...
GK
Reply #483 on:
September 02, 2012, 12:37:01 AM »
Adjusted the gear selector position.
I've just bought a new set of boots and need to get the relationship of boot to selector just right.
All I need is a nice long test ride tomorrow morning! LOL!
GK
Ducati
Monster
900S ie
Gone but not forgotten!
Betty
Reply #484 on:
September 02, 2012, 01:22:19 AM »
Quote
Well nothing actually, but I did help someone else.
She must have had a mid-life growth spurt. We raised the rear of the little beastie, put the stock stand back on and played around with the preload settings.
Unfortunately it was dark by the time we finishes so test ride will come another day.
duke8
Reply #485 on:
September 02, 2012, 05:14:22 PM »
Raised forks up to sit flush with the new speedymoto top triple on the weekend... Also fitted clip ons, new grips reservoirs, and put on all my powder coated bits n pieces. Relocated voltage regulator and did crankcase breather.. Fitted radiator covers, crankcase cover and tail chop bracket.. Almost done now, just received my rearsets this morning and will be fitting them tonight.... Pics tomorrow
'06 S4RS
kyle
Reply #486 on:
September 02, 2012, 09:03:44 PM »
Wholleeeyyy Farken!
Rowdy
S4R
Reply #487 on:
September 02, 2012, 09:09:01 PM »
Quote from: Mr.S2R on September 01, 2012, 11:17:19 PM
Pulled mine apart yesterday, too noisy. Friction material all good, plate tangs really worn, basket all worn too.
Bought a 48T unit (pack and basket) from spare shack and a new pressure plate bearing from Brisbane Bearing Service (next door to work). I'll just clean everything else up and hide it all away under the full clutch cover that I have sprayed with sound deadner. Should be nice and quiet now.
Bearing is a 6201 Koyo unit, cost me $5. Rated to 22,000rpm. Should hold up alright I guess. Looks the same as what they sell at CA cycleworks (
http://www.ca-cycleworks.com/catalogsearch/result/?q=6201
Now to wait on the postman for my package from the UK and I'm off again.
You greatly underestimate the amount of overconfidence I have.
Rowdy
S4R
Reply #488 on:
September 02, 2012, 09:09:57 PM »
Quote from: kyle on September 02, 2012, 09:03:44 PM
Wholleeeyyy Farken!
Ha, that is bad, very bad.
Mr.S2R
Reply #489 on:
September 03, 2012, 01:44:18 AM »
Quote from: Rowdy on September 02, 2012, 09:09:01 PM
Yeah basically like mine - basket bad, friction material good. How many km's has yours done? Out of curiosity why did you go the 48t. I did some reading/research and the 48t is meant to run quiter and have longer service life. I am now looking for an EVR pressure plate too!
Rowdy
S4R
Reply #490 on:
September 03, 2012, 10:48:39 AM »
I like the design of the 48t unit and a dry clutch doesn't have to be as noisy as mine was. A worn dry clutch sounds crap, a well maintained dry clutch sounds great. I would also expect the 48t to wear the friction material out long before the drive tangs and basket. That way the basket should outlive a few sets of friction plates.
My bike has done 16,000 kms. I have a closed cover but remove it and clean out the clutch dust every 2,500kms. I'm keeping the Ducati pressure plate (just fitting a new bearing) because I'll continue to run the closed cover on the clutch.
techno
Reply #491 on:
September 03, 2012, 10:15:02 PM »
Finally got around to changing the fuel filter. Not a bad job except the hose clamps on each end of the filter need replacing and its not that easy to find clips that go down to 5 or 6 mm.
All back together, started OK and no leaks (but I will check again before the next ride).
Quote from: ducmeister on May 24, 2012, 12:45:16 AM
Hey Techno you are a smart man.
Had an accident in Tasmania? -
www.tas-compo-law.com.au
GK
Reply #492 on:
September 03, 2012, 11:33:05 PM »
Quote from: Rowdy on September 02, 2012, 09:09:57 PM
Was thinking the same thing!
Glad it all held together for you. Phew!
GK
Ducati
Monster
900S ie
Mr.S2R
Reply #493 on:
September 04, 2012, 01:45:16 AM »
Quote from: techno on September 03, 2012, 10:15:02 PM
I did the same just recently too - I thought it was a bit of a pain in the ass to pull the pump/filter out of the tank though! Even though I thought I had drained it entirely fuel still kept coming out!
duke8
Reply #494 on:
September 04, 2012, 01:54:19 AM »
Fitted my new rearsets yesterday.... Pretty much done with the mods...for now
'06 S4RS
32
33
34
35
86
