February 05, 2025, 01:44:24 AM *
Pages: 1 [2] 3   Go Down
Author Topic: Apex Clip-Ons from Monster Parts  (Read 9984 times)
mostro
« Reply #15 on: July 07, 2008, 06:00:39 AM »
geez these apex sound like a bargain.
so let me get this straight: i've an 00 M750, and these would fit in that small gap above the triple clamp? i would've thought it would've been a lot harder! i'm stoked cos i'm 6' 3" and i wouldn't have any problems leaning in.
also i've seen 7, 8, and 9 degree down angles. would the angle for this model be the best? and, what're the 8 radial adjustements they talk about?
anyone got a pic with these installed?
thaaaanks
hydra
life is analog...
« Reply #16 on: July 07, 2008, 12:19:43 PM »
you know guys, i hate to say it but....
this thread is kinda useless without pics.
pleeease post pics....pretty please?  popcorn
johnster, i have an S4 as well and would really love to see a pic of yours.
S4 Foggy- tires, battery...
BE WATER
MuscovyDuc
02' M750I.E. Dark - (pearl white)
« Reply #17 on: July 07, 2008, 02:06:29 PM »
Here you go waytogo
hydra
life is analog...
« Reply #18 on: July 07, 2008, 02:30:58 PM »
Here you go waytogo
awesome MuscovyDuc, thanks!
can these adjust so the bars are straight (parallel to the ground)?
can we confirm some terms here?
radial adjustment- is this front to rear adjustment?
degrees- up and down?
BE WATER
mostro
« Reply #19 on: July 07, 2008, 04:56:40 PM »
here's what it says on monsterparts.com:
"Apex 50mm Adjustable Clip-ons
Apex 50mm clip-ons for all Monsters
9 degree down-angle with 8 radial adjustments for a custom fit to the rider
Unique two-piece clamp allows installation without removing the upper triple clamp  "
nkryptit
« Reply #20 on: July 08, 2008, 09:46:22 AM »
Here you go waytogo
Is there anything special to look out for when mounting below the top triple, as far as sliding goes.  Just tighten the hell out of them?
MuscovyDuc
« Reply #21 on: July 08, 2008, 12:41:39 PM »
Quote
I haven't tried any other postions do to the degree of difficulty with installing these. With the amount of adjustability I believe you could. I believe that ICON had his set very straight. Although I love the position that mine are in, very hard on the back if you don't have a good one. Also if the bike ever gets tipped no tank dents waytogo
If you have coffin reseviors it sucks big time to get them on. You just have to play around with them until you get them right. And they come with tourque values to tighten them to, but I choose to just to tighten the crap out of them. I found that taken my top triple off helped alot because I had to reroute alot of cables. I modified a top triple so I had to take it off anyway.
All things considered I would probably do it again, I much prefer the riding position and taking corners is awesome. Add a 14t sprocket and they become a completely different beast. Evil
nkryptit
« Reply #22 on: July 09, 2008, 04:02:20 AM »
How big a deal is taking the top triple off?  Without stands?
Airborne
Crash n' Burn
Monster S2R 800 - ALL BLACK
« Reply #23 on: July 09, 2008, 09:26:20 AM »
I remember someone saying you had to lower the head light and gauges to get them to fit right with the coffins? Anyway these with the lowered clocks and light would look badass...just sayin...
Maybe some rizmoa resevoirs too...
Add some powder coating to choice pieces in the area and taadaa. I'll get around to it eventually, maybe after indy when I'm not going to be riding it for a while on the highway.
Bellagio
Leo Vince pipes give me a
Live Fast, Die Young, Leave a Beautiful Corpse
« Reply #24 on: January 24, 2009, 09:55:23 AM »
Well, I received my Apex clipons and am intending to install under the triple.  After reading this, I'm wondering if I should just take it to the Duc stealership in the area and have them do it.  I've got an 02 620 with the coffin style reses.  I'd consider myself a novice at modifications.  Anyone agree with me or should I try to tackle this myself?
May your head gasket develop premature failure, your carb get gummed up, and your side stand fall short.
Chchadder
« Reply #25 on: January 24, 2009, 12:23:40 PM »
It's not all that hard to do, just takes some planning and time, and a good amount of patience.  There's no need to take off the top triple, and no need to lower the headlight and gauges (though I just did that mod and love it...nothing to do with the clip-ons though).  The fitment will be tight with the coffins, but it does work.  You just have to fiddle around with all of it.  Do it yourself.  There's nothing on your controls that you can really do any damage to as long as you are careful, and it is a good learning experience of doing a mild dismantle of your ride.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
Icon
« Reply #26 on: January 24, 2009, 11:46:31 PM »
Look at my flickr page if you want pics. I have Speedymoto clipons now. Good luck.
Bellagio
« Reply #27 on: January 27, 2009, 06:22:13 PM »
Thanks for the encouragement.  Tackling this project Saturday morning.  I can't wait to get frustrated as all hell, super jacked about it!
Chchadder
« Reply #28 on: January 28, 2009, 10:19:39 AM »
Take lots of pics and let us know how it goes!   chug
ghosthound
« Reply #29 on: January 28, 2009, 10:46:27 AM »
how do you prevent the "control boxes" from slamming into the tank?  with the normal bars, they get really close on both sides but i would imagine with the control boxes lower down + the tank gets fatter a little lower, they would hit the tank.   Huh?
Pages: 1 [2] 3   Go Up
