January 15, 2025, 01:31:40 AM
clean engines
Topic: clean engines (Read 9421 times)
Old-Duckman
Re: clean engines
Reply #30 on:
February 16, 2012, 05:19:19 PM »
That is why I prefer the old school of MC manufacturing. Raw aluminum...no silly painted aluminum. Shiny parts required regular polishing and rough, unpolished, cast parts just needed to be kept clean to look great. I use Gunk on all my motors, old and new but prefer the old ones for ease of cleaning...Though they do tend to weep oil more than the new Ducks and thus need cleaned more often.
mgrisham
completely stock
Re: clean engines
Reply #31 on:
February 17, 2012, 08:19:28 AM »
Bean Clean does engines as well as chains and is biodegradable.
http://www.webbikeworld.com/r3/motorcycle-chain-cleaner/bean-clean/
I'm a fan.
2003 620ie Dark
Speedbag
And the Intrepid
Since 2004!
Re: clean engines
Reply #32 on:
February 17, 2012, 06:59:17 PM »
Quote from: koko64 on February 14, 2012, 08:33:21 PM
Is that an S&S E series carb? I remember when they were all the rage.
Shit, I've got a B-series on my Panhead.....
Re: clean engines
Reply #33 on:
February 18, 2012, 12:26:48 PM »
Nice. What year? Stock or custom? I had a 72 shovel custom with pan head front end and beautiful star hub.
B series, thats old school! I always liked the air cleaner too.
Re: clean engines
Reply #34 on:
February 18, 2012, 12:35:13 PM »
As far as cleaning goes, WD40, pressure wash carefully to selected areas, tooth brush, parts cleaner on the headers, Amourall on the black barrel paint, silicon and don't let it build up.
muskrat
Re: clean engines
Reply #35 on:
February 18, 2012, 02:31:19 PM »
pig spit on the black barrel paint works wonders. nothing to do but spray.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Speedbag
And the Intrepid
Since 2004!
Re: clean engines
Reply #36 on:
February 20, 2012, 02:01:59 PM »
Quote from: koko64 on February 18, 2012, 12:26:48 PM
Custom. It's a shovel/pan mongrel.
More here:
http://www.ducatimonsterforum.org/index.php?topic=42781.0
Re: clean engines
Reply #37 on:
February 20, 2012, 03:26:38 PM »
Bloody nice job, now thats my kind of custom., and the B series looks perfect on it. It sticks out with great effect!
Nice to see an example of DPs work too. Great work there.
Pans are the best looking Harley motor for sure.
Re: clean engines
Reply #38 on:
February 20, 2012, 05:15:07 PM »
Quote from: koko64 on February 20, 2012, 03:26:38 PM
Doesn't have to be ...
RED.
NorDog
I don't feel like a
Re: clean engines
Reply #39 on:
February 21, 2012, 01:56:36 PM »
What is a panhead front end?
Re: clean engines
Reply #40 on:
February 21, 2012, 02:50:50 PM »
Just the forks off a late panhead.
They had a beautiful tapered shape, and were wider apart with a great looking hub and axel set up. The hub had a bearing cover in the shape of a star. I painted the hub black and had the star and screws chromed. The bike was black with polished alloy primary and timing cases. Motor had 74 inch bore and 80 inch crank off an evo, Crane cam, solid tappets, S&S air cleaner on a modified (by me) Keihin 38 mm butterfly carb which I ported and modified into a poor man's S&S. 5gallon tanks, ducktail rear guard, Wide Glide seat. It was kickstart only ('72 FX), Lockheed magnesium race caliper front brake (a mate welded on a Triumph caliper bracket to the pan slider) and stock "juice rear brake", Accel coil, Koni shocks, forward controls, etc.
I learned about carb modification and tuning on Harleys and Brit bikes.
Sorry I ramble... Nostalgia.
Last Edit: February 21, 2012, 03:56:22 PM by koko64
