February 24, 2025, 06:14:25 AM *
Pages: 1 ... 3 4 [5] 6 7 ... 12   Go Down
Author Topic: SR4t "project" - updated 4/2/11  (Read 60330 times)
LA
The Sleek Black Beauty
« Reply #60 on: October 14, 2008, 10:48:45 AM »
Whats going to make a difference is the large TB's I've fitted
What TB's did you fit. I thought you couldn't fit bigger one's than the 50's in the monster frame.
Wonder if the oval TB's from the 1098 would fit?
LA
TAftonomos
is without a monster :(
« Reply #61 on: October 14, 2008, 03:12:09 PM »
The 999 bodies will work with some massaging. Thing is, I can't get to the dyno until early next year, which is when I'll get them installed.  Then we can see if they will really make much of a difference.
Look for updated pics soon, PC stuff is here, and I finally got in a tube of yamahonducati bond Cheesy
jesse370
« Reply #62 on: October 14, 2008, 08:04:04 PM »
Now with those can you still use the stock airbox lower?
Also I'm guessing that with that you will need to have the ecu altered?
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover |  Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
« Reply #63 on: October 14, 2008, 10:38:15 PM »
if you have bigger TBs are you gonna change the vstacks too?
TAftonomos
« Reply #64 on: October 15, 2008, 07:33:04 PM »
It'll be a completly new setup, and yes the ECU will be tweaked.  waytogo
I just got done installing the powder coated bits, removed side panels/hid wires, re-installed the rad and oil cooler I blacked out, and made some carbon pieces (the side rad guards and a reservoir holder for my 999).  Pics tomorrow when it's light out, but it definatly looks meaner.
Once someone gets my termi exhaust, I'll be fabbing up something pretty cool in it's place.   chug drink bacon
LA
« Reply #65 on: October 16, 2008, 08:04:06 AM »
The last model 999S made 143 HP at the crank in stock trim.  A fully kitted S4RS/T should be making about the same as the stock 999S.  So I'm guessing the 54 mm TB should be worth a few HP - maybe 5 HP or so?
I know the oval TB's must be worth their weight in gold, but I wonder if they would fit. I guessing oval cross section is less than 54mm.  I know they claim they flow better than the round ones.
Look forward to you dyno run numbers.
And oh yea, If you decide to make any copies of those megaphones let me know.
LA
TAftonomos
« Reply #66 on: October 22, 2008, 02:40:54 PM »
Added some powdercoated bits to the bike.
Clutch housing, vented
Clutch PP (cause I'm too cheap to buy a 150$ one)
Billet crank cover
Alternator cover/case
rearset levers
shifter rod
shifter do-dad thing a majig
waterpump cover
radiator tube
Also added:
Billet crank inspection cover
Compwerks pegs
nichols mfg flywheel
Then I:
Painted the rad and oil cooler
changed the oil
changed the coolant to evans NPG-R
Really just a round of cosmetic mods....except the flywheel.
I happen to have my scale around, so I took a pic:
Yeah, taking 3 1/2 lbs of rotating weight does something alright.  Now the front end comes up with aggressive rollons in 3rd.  Forget first, better be careful.  Second is much quicker to point to the sky as well, but it never came up in third (got light, thats it).  I don't suppose clutching a wheelie up will be easier (less energy stored because of less mass), but that doesn't matter, because I don't do that anyway.  Low speed maneuvering is jerky now, but who rides at 5mph?
Here are the new shots.  I removed the front fairing as suggested.....I like it Smiley
As far as the megaphones go, YES, I can duplicate them for you if you like.  I'm STILL WAITING on this machinist to get me the bungs/mounts I drew up so I can finish them up.  They sound freaking great btw Smiley
As shown in the pics, now I REALLY REALLY need to get the forks anodized black...
Bbrent
'08 S4RS Tricolore
« Reply #67 on: October 22, 2008, 03:52:01 PM »
God I love your bike. Your frame pops out so much. How did you paint your radiator?
Brian
TAftonomos
« Reply #68 on: October 22, 2008, 04:59:25 PM »
I used duplicolor engine enamal on the end tanks.  Cleaned, scuffed with scotchbrite, then cleaned again.  I used 3-4 coats of the duplicolor.  Then I cleaned the fins, removed any offending bugs with a pick, and used eastwoods radiator paint.  I ended up with 3-4 coats of each, and then I did the whole thing in the eastwood paint, as there was a slight difference in sheen.
Came out pretty good ehh? Smiley   Some carbon BST's with red spokes would round it out nicely.....just need to find a deal on the wheels  laughingdp
I have crazy plans over the winter..... like cutting off the rear section of the frame altogether, and making one out of aluminum that bolts on like the SBK's.  Should be able to cut another 10-15lbs off the back end with that Smiley
LUKE
07 S4RT Green Bay, WI
« Reply #69 on: October 22, 2008, 07:22:57 PM »
Then she'll look like mine.
I used duplicolor engine enamal on the end tanks.   Then I cleaned the fins, removed any offending bugs with a pick,
I just sprayed over the bugs and it still looks good a year later.
I would love it if you could PM me details on pulling off the engine covers to PC them black.  I have been meaning to do that but I keep getting distracted.
« Last Edit: October 25, 2008, 04:52:26 PM by LUKE » Logged
flanman
« Reply #70 on: October 23, 2008, 10:32:12 AM »
That has to be one of the best color combos you can get. I love your bike and all the extra mods you've added to it. very tastefully done  waytogo
REDUC
« Reply #71 on: November 02, 2008, 02:24:19 PM »
Theo,
Could you post a picture of your gauges mounted below the upper triple clamp from the vantage point of the rider, i.e., looking down at the gauges?
dbran1949
2007 S4RS Black Termis
« Reply #72 on: November 02, 2008, 02:32:34 PM »
Bike looks fantastic  waytogo Love that red frame, just gotta convince myself I can live without the bike long enough to get mine powdercoated
TAftonomos
« Reply #73 on: February 27, 2009, 08:27:40 PM »
Theo,
Going to get to this soon!
LOTS of new mods coming.
More Ti
Ohlins suspenders
DLC coated sliders
Black anodizing and powdercoating
Aluminum frame sections?
Forged wheels?
Holy crap, what has happened Cheesy  waytogo
JTMOTO
« Reply #74 on: February 27, 2009, 10:19:58 PM »
More Ti
Ohlins suspenders
DLC coated sliders
Forged wheels?
Dibs on the Showas!!
Pages: 1 ... 3 4 [5] 6 7 ... 12   Go Up
